Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 03-23-2005, 10:13 PM   #1
techy101's Avatar
P0851 Park/Neutral Switch Circuit Low
A shot in the dark, but does anyone know what this error code means? I know it's got something to do with the sensor that detects if the car is in park or neutral allowing you to start the car. What I dont know is the the "low" means.
Thank you
Outside the dawn is breaking on the stage that holds our final destiny...
Dual In-Dash Screen Carputer Installed Check It Out.
techy101 is offline   Reply With Quote
Old 03-24-2005, 12:10 AM   #2
"Low" is the same thing as grounded - either a faulty neutral safety switch or a faulty parking brake switch. If the "brake" light is not showing on your dash, it's most likely the neutral safety switch. Take your car somewhere you won't run into anything and try to start it in drive or reverse. This will tell you for sure if it is shorted out. If it was not working at all, the car wouldn't start in park or neutral.
Good luck
Brian
finnman925 is offline   Reply With Quote
Capture GPS data at the flip of a switch Mr. Inquisitive GPS 4 02-02-2005 06:06 PM
Remote Start and Park/Neutral Position Switch Problem PatO Off Topic 6 01-28-2005 03:53 AM
Savage Switch Botton Group Buy via UK's Iconstyling.com.... TheBigDog General Hardware Discussion 3 07-21-2004 10:51 AM
Need clairification on wiring on/off switch syclone477 Newbie 9 03-23-2004 04:59 PM
Help With Extending Laptop Docking Station's Power Button JeffesonM General Hardware Discussion 10 04-14-2003 01:13 AM
