The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 04-06-2005, 01:16 PM   #1
Munysoft's Avatar
Vehicle: 1996 Fiat Duna CL 1.6
My Photos: (0)
Exclamation ISO High-Speed Interface with Motorola MC33290
First of all hello to everyone in the forum.
I've found this schematic for a "High-Speed ISO Interface" with a Motorola Chip, the MC33290, this chip it's a ISO K Line Interpreter. I'm trying to build this interface but it dosn't work... I have a few doubts, The pinout of the chip in the schematic is not the same of the Motorola Datasheet. I've tried with many ways to connect the MAX232 but I can't make it work Anyone could make it work??? please contact me. I have a lot of info to trade
P.D: Sorry about my lacky english
Munysoft is offline   Reply With Quote
Sponsored Links
Old 04-06-2005, 01:43 PM   #2
shotgunefx's Avatar
Vehicle: 2002 Chrysler Sebring Coupe LXI
My Photos: (30)
Do you have a link to the schematic your trying to build? Not a lot to go on here. What type of max232 do you have? Do you have the 5 external 1uF capacitors? I'm not electronics wiz by any stretch, but I've used the max232ab a few times and come across it a lot in things I've read.
shotgunefx is offline   Reply With Quote
Old 04-06-2005, 02:01 PM   #3
Munysoft's Avatar
My Photos: (0)
Here's the link to the schematic http://www.skpang.co.uk/highspeed-iso9141.htm
I'm using a MAX232N from Texas Instruments with 1uF external capacitors. The MAX of the Schematic it's an MAX232ACSE (or MAX232A...it's the same) but I couldn't find it here, the only difference that I've noticed between the MAX232 and the MAX232A it's the Data Rate (kbps).. 120 for 232 and 200 for 232A, and the external capacitors.. But I have to work as well with the 232 as with the 232A no??....
I'm using VAG-COM software, in the test appears "Interface not ready"... If you know another soft that may work with this interface please let my know!!
Thanks!!!!
Old 04-06-2005, 02:27 PM   #4
shotgunefx's Avatar
My Photos: (30)
Thanks!!!!
Could be any number of things so not sure what to tell you, did you check the easy stuff like solder joints with a multimeter? Did you test the power regulator?
Old 04-06-2005, 02:39 PM   #5
Munysoft's Avatar
My Photos: (0)
I'm, doing it in a protoboard, the power regulator it's OK, I've checked and all appears to be fine but it dosn't work.... Please tell me anything you think it could be, I'm runnig out of ideas :S....
Old 04-06-2005, 02:51 PM   #6
shotgunefx's Avatar
My Photos: (30)
Like I said, I'm no expert by any means. It could be a bad chip, I've had it happen. Normally breadboards are ok as long as the circuit speed isn't too high, and you're talking upwards of 4MHZ, so that shouldn't be a problem. You said the pinout was wrong, which one? The motorola chip? Did you wire it according to the schematic or the datasheet? You might want to try adding leds and appropriate resistor to RX/TX so you can see if anything is being transmitted or received.
Old 04-07-2005, 11:46 AM   #7
Munysoft's Avatar
My Photos: (0)
In the datasheet appears one pinout and in a drawing next to this pinout appears another!!! I found the correct datasheet, used the pinout from there (It's the same as the schematic) and still doesn't work, I changed the MAX232 and the MC33290 4 times to be sure.... NOTHING HAPPENED!!!
Thanks!!!!
Old 04-08-2005, 05:03 AM   #8
shotgunefx's Avatar
My Photos: (30)
Not sure what to tell you. You might want to try posting your question with relevant links at electro-tech-online or even bit-tech
Old 04-21-2005, 05:36 PM   #9
Munysoft's Avatar
My Photos: (0)
Well... finally I made the PCB and works... I don't know yet what the problem was but it doesn't matter
Regards
Old 04-22-2005, 04:20 AM   #10
shotgunefx's Avatar
My Photos: (30)
Congrats, if you get a chance, let us know how it goes and what worked.
Sponsored Links
Old 05-19-2005, 10:35 PM   #11
Munysoft's Avatar
My Photos: (0)
I've tried with several VW and SEAT, it works perfectlly, it's really fast but I can't find a Renault soft....:S:S:S
Sponsored Links
vB code is On
Trackbacks are Off
FS: NICs, Laptops, & Cable Modems Coeus Classified Archive 5 05-04-2005 03:00 PM
Vcast high speed phone service Punisher Wireless Communications 8 03-28-2005 11:10 PM
problem with my usb to ide cable. high speed usb drive? DSM97RS General Hardware Discussion 14 05-19-2004 12:10 AM
high speed mobile/satilite internet pete35887 Wireless Communications 3 04-10-2004 12:12 AM
iso / vag interface differences? 00CericaRuss Engine Management, OBD-II, Engine Diagnostics, etc. 7 11-14-2003 01:06 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
