The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 05-16-2005, 02:19 AM   #1
My Photos: (0)
MPG for an Impala LS
Hi, I have a 2004 Impala LS and it doesn't have the center console in it to display the fuel MPG. Is there anyway to add this into my car? I'm not nearly as advanced as 99% of you in this forum. I'm having a Pioneer AVIC-N1 stereo installed in my car and it has a fold out touch screen LCD on it. I'm pretty sure I can feed video out to it through a video in source on the AVIC-N1. But I need to find a device that will calculate the miles per gallon to display it on the screen. Any ideas?
(I'm not much of a programmer so I'm no where good enough to write code to make this happen. I took the first class of programming in C++ and that's it. I am not going to school to be a programmer. I pretty much need a solution that is pretty straight forward.)
dmorlow is offline   Reply With Quote
Sponsored Links
Old 05-16-2005, 02:05 PM   #2
My Photos: (0)
I don't know if you can add the overhead console, as mine already came with it installed. You might try picking one up at a junkyard. Check out www.newimpala.com or www.naioa.com and you might find some answers there.
IronMonkeyGF is offline   Reply With Quote
Old 05-17-2005, 11:40 AM   #3
Registered User
My Photos: (0)
Im thinking maybe? but probably not. I was thinking about doing the same thing on two of my cars. Same engine and ecu. I could still try it but overall it would be time comsuming.
Here are some options.
1) http://www.scangauge.com/
2) http://www.jcwhitney.com/autoparts/P...20per%20gallon
3)http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
1)"ugly but it works!" MPG,Instant and average!
2)If you can find a place to install it works!
3)Auterra's Dyno-Scan for Palm CAN Lots of features! Your going to have to buy the software and a palm.
I have 2 and 3. Depending on how much you want to spend its up to you. Get 2 if you on a tight budget. If money isnt a problem. I would go with 3 thats the best deal. But nothing wrong with #1 that probably your best bet.
Gunmaster is offline   Reply With Quote
Old 05-26-2005, 11:58 AM   #4
My Photos: (0)
Impala Driver Info Center Upgrade
I have an 04 Impala LS and I just ordered the overhead console from a Junkyard... It should be here in a week or so and I'll let you know how the install goes...
bbengineer is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Hacking into Fan speed switch... Dexter Hardware Development 10 07-12-2005 11:11 AM
LS 2.0 and Britelife combo -zip- FrodoPlayer 1 04-21-2005 08:57 PM
Fan problems on my carpc JohnChimpo General Hardware Discussion 2 12-10-2004 08:25 AM
Do you need a very compact graphic fan controller? more mods LCD/Display 15 09-24-2004 06:17 AM
Case fan modified. Safe? cafn8 Off Topic 7 03-18-2004 10:57 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
