Technical data from obd2
Hello,
I would like to know if it is possible, using an obd2 datalogger (AutoWatch for example), to count the number of motor starters (when the driver starts the car with the key)?
Is it also possible to store from obd2 the times of uses of the headlamps? I mean to detect when the headlamps are activated either the main beam or the long beam.
But if it is not possible which solutions could work?
If anyone has any suggestions I will appreciate it. Thank you.
