08-08-2005, 01:47 AM
#2
Vehicle: 2006 Ford XR6 Turbo Ute
the cap will be just ur timing and emisions read out.. not really anythign exciting..
check out my toyota.. in my sig its a 95
08-08-2005, 02:01 AM
#3
So as for engine readouts, I'm screwed? Ohwell. Wish I had an extended cab, my truck is a single cab, I've spent the entire 2 years I've had it attempting to install a sub in the non existant space behind the seat.
08-08-2005, 10:40 AM
#4
MySQL Error
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
If my 89 Supra doesn't have OBD2, you truck won't.
Yes, that is Toyota OBD1, You can short the terminals to check for trouble code and stuff but basically not much usefull out of that port.
08-21-2005, 08:27 AM
#5
Vehicle: 1993 Toyota Corolla
Toyota started implementing OBD-I in the '89 Cressida (7M-GE engine). I have found some info, but not enough to allow me to read data from my '93 Corolla. This is all I have (copy-paste from a Toyota PDF):
- There are three types of serial data: OBD, OBD-II and V-BoB (Vehicle Break Out Box). We're interested in OBD.
- Many Toyota vehicles with OBD, manufactured since 1989, have serial data stream available on the VF1 terminal of DLC1 (Check connector) or the ENG terminal of DLC2 (TDCL).
- Vehicles which support a serial data stream can be identified by the presence of a TE2 circuit. Depending on the vehicle, there can be as many as 20 different sensor, actuator and diagnostic data parameters represented on the OBD data stream. Accessing serial data on any of these vehicles is a simple matter using the Diagnostic Tester.
After that there's a description of the V-BoB which is conncted in series with the ECM and gives a readout of all the signals. BTW, I couldn't find a V-BoB for sale anywhere... The next paragraph is as follows:
- The OBD Diagnostic Circuit:
This unidirectional data stream typically consists of 14 to 20 data words representing primarily sensor inputs and three outputs; injection pulse width, spark plug advance angle, and idle speed control command. Data is transmitted at a rate of 100 baud, updating on the Diagnostic Tester display approximately once every 1.25 seconds. Depending on application, the data is accessed from either DLC1 or DLC2. Data is triggered by grounding the TE2 circuit and reading the VF1 circuit.
I have found out that the DLC1 connector is the one SovereignScorn shows in the attached images ("Diagnosis" somewhere under the hood), but in my Corolla it seems a little different. I haven't tried to read anything from that connector, because i don't have any texts explaining the interpretation of the data. If anyone can help with that I'd appreciate it a lot!
| Thread Tools |
| Display Modes |
Linear Mode
