Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Notices
Old 01-15-2006, 11:55 AM   #1
Question OBD 2 for HP iPaq
I was wondering if anybody uses or knows of any software and/or hardware for use with the Hewlett Packard iPaq? In the shop I use the cable and software from www.obd-2.com but that is pretty much stationary. I am looking for something to get information while I am driving. I have the iPaq pocket PC so I am hoping I can find something to work with that. Also, will the cable from www.obd-2.com work with other programs? And last, it has a serial connector, can I just get a serial to USB converter to use the cable? Any help would be greatly appreciated!!!
Dan
Drdan524 is offline   Reply With Quote
Advertisement Sponsored links
Old 01-15-2006, 01:21 PM   #2
JimmyFitz's Avatar
What model iPAQ?
Some iPAQ's have a serial and a USB port both built in to the synch connector. Some models (like the 1900 series) only support USB. You need one that also has serial and a serial port synch cable and maybe a null modem adapter. I haven't done this with mine, but I remember seeing this on one of the OBDII hardware vendor sites. Search a little, it wasn't too hard to find. Let us know what you come up with and I will try it too maybe.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 01-15-2006, 01:50 PM   #3
Thats the thing, I have the RX1950 and I only have the USB sync cable. Will the rs232 to USB converter work? I found some free software for pocket pc, but I can't tell if or how well it works without connecting it to the car. Just looking for any help and I have been, and will keep doing a lot of research and post what I find.
Dan
Old 01-15-2006, 04:32 PM   #4
JimmyFitz's Avatar
No USB host on 1900's
Dan
No, it won't work. The PPC cannot act as a USB host. You might look into using Bluetooth if your PPC has that, along with a BT/serial for the OBDII scanner end. If your 1950 doesn't have BT, I don't think there are any other options. Time for an upgrade?
~Jimmy
Old 01-16-2006, 01:16 PM   #5
I will have to look for Bluetooth possiblities. I just got the iPaq for christmas and I like the way it works and don't really have the money for a new one since the next step up was over $100 more. I am looking with Snap-on and Matco Tools, but I am going to see what bluetooth possibilities are out there.
THanks
Dan
Old 01-18-2006, 07:56 AM   #6
In my search of a bluetooth OBD-2 scan tool, I found a bunch of from software. http://www.qcontinuum.org/obdgauge/ is going to be my software of choice I believe depending on what software the scan tool comes with. For the scan tool, I think I am going to purchase the Car-pal from http://www.vitalengineering.co.uk/ . It's a little pricey at $205 shipped, but I am a mechanic for a living and it seems to be the best all around scan tool to serve the purpose I need. I hope this helps others who are looking.
Dan
Old 01-18-2006, 10:42 AM   #7
JimmyFitz's Avatar
No Bluetooth on RX1950?
Dan
I just checked out the specs on rx1950 and it doesn't appear to have Bluetooth.
~Jimmy
Old 01-18-2006, 11:07 AM   #8
JimmyFitz's Avatar
Wireless BT would be ideal for a mechanic
DrDan,
I hope you find a good solution for your PPC-OBDII. I think the Bluetooth wireless would be worth the extra cost for the ability to monitor while your head is under the hood, in the driver's seat or anywhere else near the car. There are some Pocket PC forums where you might find other useful info:
www.pdastreet.com
http://www.pocketpcmag.com/_top/bestsites.asp
~Jimmy
Old 01-18-2006, 08:59 PM   #9
OK, I just upgraded my PPC to a HX 2495, not a lot better but it does have Bluetooth. So does that improve my chances of anything. It's pretty much the same PPC I guess. Just wondering if this helps any. Thanks!!
Dan
Old 01-19-2006, 01:27 AM   #10
JimmyFitz's Avatar
BT or serial cable should work with that one
Dan
The HX 2495 has bluetooth so that will work if you like the idea of wireless OBDII monitoring. But with that model, you can PROBABLY use the serial port cable and some cheaper OBDII scanners. Here is a link to the sych cable that you could try:
http://www.shopping.hp.com/webapp/sh...e=FA122A%23AC3
I can't promise this will work but I read somewhere that it would. You would also need a null modem adapter. Those are cheap. Good luck.
~Jimmy
Old 01-19-2006, 01:27 PM   #11
OK, now that I have caught up to the 21st century, what is a null modem adapter and what does it do? Also, I have the obd2 cable from www.obd-2.com, will that work or does every software read from the tool differently?
Dan
Old 01-23-2006, 12:51 PM   #12
OK, another question now since I have the HX2495. Now that I have a iPaq with serial port capabilites, does anybody know of software, preferably free, that can be used with Windows mobile 5.0? I downloaded a couple and they all require eMbedded Visual Basic which doesn't run on Windows mobile 5.0. Does anybody know a fix? Either I need a program that will run on Windows 5.0 or I need a fix so I can run the programs that require Visual basic.
Dan
Old 01-23-2006, 03:10 PM   #13
JimmyFitz's Avatar
Dan
A null modem adapter crosses the transmit/receive lines inside and allows you to connect devices together that weren't necessarily meant to be. If your ODBII device cable and your PPC sych cable are the same sex, you might need an adapter.
I am not familiar with Win Mobile 5 so if you have a particular software app you want, contact the vendor and see if they have a new version in the works. Maybe they will let you beta test for them if they do.
~Jimmy
Old 01-23-2006, 10:30 PM   #14
Yes, I am definitely going to need a null modem adapter. And I will contact the vendors for the software. The software that I liked the best was http://www.qcontinuum.org/obdgauge/ . But thank you for all your help!!!!
Dan
Old 01-25-2006, 01:24 PM   #15
By the way with car-pal unit you get free software for your PC, Pocket PC (PDA), Palm even Windows Mobile Smartphone.
The software is also available separately
Shewan
shewan is offline   Reply With Quote
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 02:06 AM
OBD 1 Diagnostics software? MaleBuffy Engine Management, OBD-II, Engine Diagnostics, etc. 3 06-13-2005 08:05 PM
OBD Diagnostics connected all the time? Zoltan Engine Management, OBD-II, Engine Diagnostics, etc. 7 08-23-2004 03:47 PM
OBD USB or LPT1 Connectors? Ritalin Kid General Hardware Discussion 11 09-19-2003 11:01 PM
Using an IPaq as display & touchscreen input malloc LCD/Display 6 08-16-2003 11:17 AM
