The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 02-23-2006, 02:50 PM   #1
Vehicle: Nissan 240SX
My Photos: (0)
Nissan Consult cables
Most Consult cables Ive seen have a little PCB between the RS232 plug and the Consult plug like this one:
Then I ran into this one:
Its sold by Blazt.biz and its virtually a straight thru cable with no PCB or anything. Has anyone used this cable? I just dont see how it could work.
My first carPC!
MP3/CD player
Celeron 633MHz - 10GB Seagate - 64MB PC100 - Win XP
Soon to actually find its way into the car!
hannibal is offline   Reply With Quote
Sponsored Links
Old 02-23-2006, 02:56 PM   #2
Vorex's Avatar
Vehicle: 1997 Nissan 240SX
My Photos: (0)
alot of that board in the top picture is wasted space...
inside of the serial connector with the blazt.biz cable...
I personally haven't used either one, but am also looking at purchasing one...so anyone who has please chime in
- Vorex Out
Vorex is offline   Reply With Quote
Old 03-21-2006, 08:14 AM   #3
My Photos: (0)
New USB cables as well
Hey I just came across the same item at this web site www.blazt.biz/us . It appears they now have a USB cable as well...and just as small. Anyone use it? Why would USB be better??
whimz240 is offline   Reply With Quote
Old 03-21-2006, 12:59 PM   #4
ikon240's Avatar
My Photos: (0)
BlaZt cable
well i just ordered one, so I will report back when i get it and have the chance to play with it. I am hoping that the cable will work with a free OS X version of Conzult that I found (*crosses fingers*). In case that fails, i bought the whole package with the PC based software.
ikon240 is offline   Reply With Quote
Old 03-21-2006, 01:10 PM   #5
ShawJohn's CarPC Specs
ShawJohn's Avatar
Vehicle: 1999 Nissan 200sx S14a (280bhp)
My Photos: (0)
I use the same cable but got mine PMSL developements... There is in indeed a circuit inside the plug.
I wouldn't bother with the USB ones as the USB-Serial converters aren't very reliable and may also cause resume issues... Bog standard Serial is way more reliable. And no issues with port numbers changing etc... Unless you use a Mac ofcourse (don't they only have USB). Then I think you may struggle with software though
I wouldn't swap mine for anything Cost me about £45 delivered from Aus. IIRC.
Im currently testing the latest Beta of Nissan Datascan 1.5b too
Pushing Tom the developer to make the app more CarPC orientated as it was originally designed for Laptop style temporary diagnostics, not for being on all the time on a CarPC with a 7" screen. I've asked him also to look at either making it skinnable, or making an SDK... Watch this space
ShawJohn is offline   Reply With Quote
Old 03-21-2006, 02:45 PM   #6
My Photos: (0)
I'd stay away from the USB. That may be worth it for someone using a laptop, but if your planning a permanant (carPC) installation, serial is probably a better solution.
I found a guy on a forum that was building and selling these. Unfortunately, my car was totalled at the beginning of the month, so I'm back to square one...
My first carPC!
MP3/CD player
Old 03-21-2006, 02:56 PM   #7
ShawJohn's Avatar
My Photos: (0)
You can DL the schematics but by the time you've sourced all the parts and made your Heath Robinson cock up, all to save £20, you might end up with something that works or doesn't work, or WORSE - ****s up your ECU or PC.
Buy the cable and support the guys who are writing the software and doing all the dev work.
Don't be a tight wad
Old 03-21-2006, 02:57 PM   #8
ShawJohn's Avatar
My Photos: (0)
And as has been said, I'll say it again - STICK WITH SERIAL not USB
Old 03-27-2006, 07:58 PM   #9
ikon240's Avatar
My Photos: (0)
lesson learned
So AFTER my last post can you guess which one I ordered? Yup, the USB one. Works great with the datascan software i got with it for the pc. But consultan doesn't seem to work with the USB cable version... ie it's message at startup is: no available serial ports detected. has anyone else played with these cables with Consultan for OS X? Can I install a serial port somehow that uses the usb connection?
Consultan here: http://members.cox.net/~epooch/consultan/
USB Cable here: http://www.blazt.biz/
Old 03-28-2006, 12:00 AM   #10
Zac
Vehicle: 96 Volvo 850R
My Photos: (0)
ikon - completely wild guess but it's possible that consultan is only looking at say com1-2 for the consult cable and the usb serial conv gets set at whatevers avail (ex the last usb->serial i plugged in got assigned com11 because i had so many drivers installed)
if consultan only seems to check the first few then see if there's a way you can change the com port #
Zac is offline   Reply With Quote
Sponsored Links
Old 03-28-2006, 10:24 AM   #11
ikon240's Avatar
My Photos: (0)
that was on a pc tho right? I am not sure where the equivalent settings are on a mac. can anyone help me out?
Old 03-28-2006, 11:01 PM   #12
noodles's Avatar
Vehicle: 2002 Acura RSX Type S
My Photos: (0)
If the software doesn't have USB com port functionality built in... you may be able to "make" a virtual serial port by using something like this:
http://www.ftdichip.com/Drivers/VCP.htm
noodles is offline   Reply With Quote
Old 03-29-2006, 08:44 AM   #13
CarFrontEnd Creator
iamgnat's CarPC Specs
iamgnat's Avatar
Vehicle: 04 Ford Escape
My Photos: (0)
Macs (with OSX) don't work quite the same way. There are no COM ports like in windows. What you have instead is serial ports and their names are arbitrary based on the driver software.
You need to find out whose USB -> Serial chip they are using and see if that chip MFG offers a Mac driver. FTDI (linked by noodles) is a great company, they actually even have a Beta Intel Mac driver they'll send you if you ask.
If they will let you return it, I would recommend getting the serial version and then pick up a known Mac compatiable USB -> Serial adapter (keyspan, iogear, etc...) to use with it as that would be the easiest.
EDIT:
Ok I took a look at the website. They give you an EXE file named CP2101_Drivers for the drivers for it. That is for the CP2101 chipset which is made by http://www.silabs.com. They do have Mac OSX drivers (and linux too), but the last time I looked into them they burried them in the Windows EXE file that is an installer rather than a self extracting ZIP file
Check their website, or install the EXE on a PC and then look for the OSX drivers there.
-dave
iamgnat is offline   Reply With Quote
Old 03-29-2006, 07:52 PM   #14
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (29)
If I understand properly, the serial port on OSX is actually just a file in the /dev/tty folder. When you select your serial port, you are actually just connecting to that file. The driver is what gives the file it's name and puts the information there. Not sure how it works when you write to the port, but it does.
You also have to enable the port in your networking control panel. I notice that the ports aren't available unless you have a serial device plugged in.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is online now   Reply With Quote
Old 03-29-2006, 08:10 PM   #15
ikon240's Avatar
My Photos: (0)
here is the zip with the mac installer for said driver
EDIT:
-dave
here is the file:
Sponsored Links
vB code is On
Trackbacks are Off
Nissan 100 NX (1600) Part I (installing cables and layout) videodok Show off your project 8 08-25-2005 03:50 PM
OBD II questions CAMPPAIN Engine Management, OBD-II, Engine Diagnostics, etc. 27 05-10-2005 02:54 AM
5x XMDirect Cables $25/ea shipped. hevnsnt Classified Archive 34 04-12-2005 12:57 AM
Lilliput with extension cables (9-pin mini-din vs. VGA) BriCubz LCD/Display 3 09-03-2004 07:07 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
