12-14-2006, 11:51 PM
#46
I put this software in my lap top.
Now, how I can connet car with my lap top?
Thanks...
12-15-2006, 07:46 AM
#47
Thanks...
You need an interface such as this
www.obdpros.com
There are also other manufacturers that make similar interfaces
OBD-DIAG (also author of the fine software that you installed),OBD2allinone, scantool.net etc
Do your research and you will be able to decide yourself which one is better.
I am partial to ObdPros since I make those
Paul
www.obdpros.com
12-15-2006, 02:22 PM
#48
I noticed that this thread started as a question about waning a decent looking OBD software. For anybody with Subarus, or an ELM module.
I just released a new version of my software that now supports the ELM 323 interface module. It's 100% opensource and freeware.
http://jdash.sourceforge.net
It should work with any ELM/OBD interface.
The main idea behind this software was to make a skinnable "Dashboard" to interface with your car.
Perhaps some of you might find it usefull.
12-15-2006, 02:25 PM
#49
Vehicle: Subaru Forester
Subaru here. will try it out on a Forester/ELMScan5 interface
12-15-2006, 03:04 PM
#50
Since you have a subaru, you might want to try the Tactrix Open Port cable. It will perform 5 times faster than the ELM module.
12-15-2006, 03:06 PM
#51
:( sad but true
maybe.., but not in 1998 Forester.
12-15-2006, 03:14 PM
#52
Pretty much any cable will perform 5 times faster then an ELM based module.
12-15-2006, 03:17 PM
#53
This has nothing to do with this post. I thought we are discussing about free software here.
12-15-2006, 03:23 PM
#54
My apologies, I realize you already own an ELM interface. Digimoto offers a free version of its software as well.
Edit: Digimoto Lite does support the ELM interfaces as well, as will our free version of our 5.0 software. There is nothing wrong with the ELM interface, it is simply a little slow. You can get single protocol interfaces on ScanTool.net for like $50 now ~ imo that is a great deal if you are shopping on a budget.
12-15-2006, 08:04 PM
#55
imho that's probably going to be more costly in the long run, think about it... you will be getting a new car at some point and then you will be spending more money on a unit that is compatible with that other car, I think in the long run it's much better to stick with a multiprotocol unit, specially since nowadays you can get one for just $ 35 more than a single protocol unit.
Paul
www.obdpros.com
12-15-2006, 09:00 PM
#56
Paul
www.obdpros.com
Point well taken, the only reason I would suggest a single protocol interface is when someone simply can't afford a more expensive option. Honestly, for $35 more, the OBDPros interface is a much better decision. If you are going to pay $130ish for an interface though, I would just advise looking at other options other then the ELM simply because you can get the exact same functionality in another interface that pulls at a much faster rate.
12-20-2006, 12:52 PM
#57
Could someone post a download link to this, as i've spent ages on the site, and cannot download it for my life!!! Tried allsorts, even different browsers!
Thank You!
12-20-2006, 12:53 PM
#58
12-20-2006, 02:03 PM
#59
Vehicle: 2007 Subaru Forester STI
Paul
www.obdpros.com
If you ONLY want access to OBD-II interface.......if you want to access SSM (or other manufacturer specific protocol, e.g. Mitsu EVO) and OBD-II the tactrix (OpenPort) cable is a better buy, especially if you want to read/flash your ROM on a post 2001 car.....
12-20-2006, 02:20 PM
#60
Vehicle: 1999/VW/Passat
Great software, I want it for my vw passat
One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
| Thread Tools |
| Display Modes |
Linear Mode
