The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 12-20-2006, 02:52 PM   #61
My Photos: (0)
Quote: Originally Posted by marky9074 View Post
If you ONLY want access to OBD-II interface.......if you want to access SSM (or other manufacturer specific protocol, e.g. Mitsu EVO) and OBD-II the tactrix (OpenPort) cable is a better buy, especially if you want to read/flash your ROM on a post 2001 car.....
True, I wonder if all the tactrix cable does is the voltage level translation so the ECU can communicate with the PC or wether it has more smarts to it.
The reason being if all it does is voltage level translations there might be a way to get the ELM style OBD II units to play a dual role...
michbound is offline   Reply With Quote
Sponsored Links
Old 12-20-2006, 03:02 PM   #62
Vehicle: 2007 Subaru Forester STI
My Photos: (0)
That would be handy, as mugurg has just got an ElmScan 5 and found out his MY99 is not OBD-II compliant (just SSM).....seems that his dealer gave him bum information!
marky9074 is offline   Reply With Quote
Old 12-20-2006, 03:06 PM   #63
mugurg's CarPC Specs
Vehicle: Subaru Forester
My Photos: (0)
if i can make it work... i am ready to make any test suggested, no matter if i destroy the great ELM. I don't particulary care so much, i just want to read the damn SSM...and if i burn the damn thing, i will buy another device and so on.
My second Subaru skin
Full screenshots second skin
My car photos
CarPC Progress
■■■■■■■ - 75%
mugurg is offline   Reply With Quote
Old 12-20-2006, 03:14 PM   #64
My Photos: (0)
http://www.vwrx.com/selectmonitor/RS232-Discrete-B.pdf
http://www.vwrx.com/selectmonitor/RS...tegrated-B.pdf
These might help....
Old 12-20-2006, 03:16 PM   #65
My Photos: (0)
http://forums.openecu.org/viewtopic.php?t=138
Old 12-20-2006, 03:43 PM   #66
My Photos: (0)
i have these mark, thank you, and read that post yesterday. twice..
but: where the hell should i stuff my K and L line into the damn ELM port?... (
My car photos
CarPC Progress
■■■■■■■ - 75%
Old 12-20-2006, 04:23 PM   #67
My Photos: (0)
Yeah, I know you have them! It was for Michbound...I thought he might shine some light on the situation....
Mark
Old 12-20-2006, 04:27 PM   #68
My Photos: (0)
sorry...
ohh.. my bad.
I am ready anytime someone will pop an advice for me...
My car photos
CarPC Progress
■■■■■■■ - 75%
Old 12-20-2006, 04:29 PM   #69
My Photos: (0)
You will not be able to do anything with the K&L line as you car does not have them......!! (pins 7 & 15)
But as per the OpenPort description the pin 9 L line and pin 11 Vpp Line appear to be the SSM pins, but yesterday on VWRX we identified these as pins 12 & 13, which is the same as your connector, so now I am really confused....
Is SSM pin 12&13 as per pre 2001 cars or is it 9&11 as per the OpenPort description....
Old 12-20-2006, 04:30 PM   #70
My Photos: (0)
my car has only 12-13 pins... damn subaru protocol...
My car photos
CarPC Progress
■■■■■■■ - 75%
Sponsored Links
Old 12-20-2006, 04:49 PM   #71
My Photos: (0)
OK, I have had a think.
I believe on the tactrix cable:
Pin 7 is both ISO 9141-2 K Line and SSM/GST
Pin 15 is both ISO 9141-2 L Line (and SSM??)
Pin 9 is L Line (Subaru Specific....)
Pin 11 is Vpp (Flash voltage)
So we can assume that 12&13 are SSM on your connector. I would jumper across pins 7-12 & 15-13 on the Elmscan to the scoob connector. I assume this is simple tx/rx and if it does not work flip it around i.e. 7-13 & 15-12?
Mark
Old 12-20-2006, 04:55 PM   #72
My Photos: (0)
In fact you are only going to need the K line as this is TX/RX so pin 7 to either 12 or 13......
Do you need DTR/DSR line which is 15? Not sure?
I have been reading this, not quite the same but explains some of the SSM/OBD pins.. http://forums.openecu.org/viewtopic....&highlight=ssm
Old 12-20-2006, 05:03 PM   #73
My Photos: (0)
Mark, those are signal lines. Even fliped should not do any harm. I will give it a shot with 7 going on 12 for a start, but in a few days, as i am going in a short holiday tomorrow at 6 AM.
DTR and ASR stands for Data Terminal Ready and Data Set Ready, so the communication should be done by waiting for DTR signal...? Some systems that require DSR typically also raise Data Terminal Ready (DTR) to indicate they are ready to go but are just waiting for the other "partner". At least i remember so...
My car photos
CarPC Progress
■■■■■■■ - 75%
Old 12-20-2006, 05:12 PM   #74
My Photos: (0)
A couple more, everyone seems to make up their own cable...
Old 03-17-2007, 09:12 PM   #75
necrolyte's Avatar
Vehicle: 2002 Ford Ranger
My Photos: (0)
sorry to drag up a maybe old thread, but is there a way to convert the km/h and other units to standard units instead of metric? This would be very handy
Other than that, looks great.
necrolyte is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Looking for Non ELM software for OBD II Refael Azi Engine Management, OBD-II, Engine Diagnostics, etc. 13 07-19-2006 10:32 AM
South Africa ? Any free GPS software peter6960 GPS 1 12-28-2005 10:01 AM
Supplying FP as free software? Gredd FrodoPlayer 8 10-07-2005 12:17 PM
Free trial copies of ESX Manager software 12Vsystems Software & Software Development 24 05-21-2005 09:58 PM
Free software MasonAltima Software & Software Development 2 05-01-2004 02:26 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
