03-20-2007, 06:47 PM
#76
I believe I saw an option to specify a conversion ratio for some of the input fields in obd-diag.
03-26-2007, 05:29 PM
#77
would not work with my ELM327 compartable hardware
Quote: Originally Posted by michbound
Just tested it with the OBDPro interface and it works great
Paul
OBDPros
I have the OBDPro hardware and downloaded the OBD-DIAG software from the website, but would not work in my car. Please advice. I get the message " can't find the AVG diagnostic". I thought it works with ELM compartable hardwares?
Please help.
03-26-2007, 05:52 PM
#78
Hi,
I am new to this site and I would appreciate your help. I just bought the OBDpro hardware which is ELM 327 compartable, but I am unable to use the freeware of OBD-DIAG. I keep on getting the message" can not find AVG diagnostic). I downloaded it from this link:
http://www.er-forum.de/obd-diag-dl/i...AG%20Software&
.I downloaded the last one (OBD-DIAGV1.01.00.zip). When I got the error message I also download the AVG internal and the AVG supertool but it still didn't work.
Please help. I tried to click on the download link on your message which stated that it worked with ELM 327 and you gave a download link but that just brought me to a blank page.
Thanks in advance
Patrick
08-15-2007, 01:36 PM
#79
new soft for AGV interface (OBD-DIAG 2055 - 4500) www.obd-diag.com
MoDIAGexpress
09-09-2007, 02:13 PM
#80
Vehicle: 03 Focus Zetec
Quote: Originally Posted by Patrick123
Hi,
Thanks in advance
Patrick
You downloaded the wrong file. It's the last one on this page:-
http://www.er-forum.de/obd-diag-dl/i...IAG%20Software
I know the description is German but the program is English :-)
You must specify the com port in the config page too. On one of my PC's the config button froze the program so I edited it manually in the OBD-DIAG.ini file. OBD-DIAGV1.01.00 definitely supports the ELM hardware because I am using my ELM320 with this version of the software.
It would also appear that the com support is limited....so if you are using a USB ELM327 I suggest that you change the port to com1 and specify this in the config.
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
09-20-2007, 03:44 PM
#81
I've been goin over the code now for about two hours and granted I am no programmer or anything, I cannot find anywhere to change the calculations for the speed or even the pressures for the fuel and what not. Anyone give a little help?
appreciate anything i can get!
03-25-2008, 03:40 PM
#82
hi Folker
hello , i have a interface ELM 327
but no working with OBD-DIAG software , you think if my interface is compatible with that software ? when i push the botton for connect, search but never connected the interface , i put in the setting the correct com , what bit i have to put on the com 9600 or 38400 ?
in the software no have that option to put the bit of com ...
, i connect my interface with other software and working perfect sacantool,net , scanmaster ELM , but i want used that software , can you help me , thanks mikee
03-25-2008, 03:44 PM
#83
Vehicle: 2007 Mazdaspeed6
I have the same problem w/ my OBDPros elm unit.
2007 Mazdaspeed 6
03-26-2008, 07:25 AM
#84
Custommx3,
use the OBDDiag from the shipped CD, I think there are two versions of the OBDDiag and the one on the website will not work as it is probably specific to the OBDDiag hardware.
Paul
www.obdpros.com
03-26-2008, 12:29 PM
#85
where i can download the other version of software of OBD-DIAG , maybe working with my interface , thanks mikee
03-26-2008, 01:32 PM
#86
Custommx3,
Paul
www.obdpros.com
Will do.. thanks!
2007 Mazdaspeed 6
03-31-2008, 02:21 PM
#87
hello , anyone can help me with my interface what no work with OBD-DIAG software ..
thanks
03-31-2008, 04:09 PM
#88
Does it work with any software?
I assume you probably have a faulty unit.
2007 Mazdaspeed 6
03-31-2008, 05:20 PM
#89
hi , yes my interface work with other software , scantool.net , ScanMaster-ELM , but i want used the OBD-DIAG software , anyone know if i can modified somethink inside of my interface or change somethink ?
my intergace have inside 327 chip
thanks
| Thread Tools |
| Display Modes |
Linear Mode
