03-12-2006, 08:23 PM
#1
PCMSCAN integrated into RR
Hi all, I'm integrating PCMSCAN into my Road Runner front end. Here are the results so far..
PCMSCAN App standalone:
RR Menu:
PCMSCAN Embedded:
The cool thing about PCMSCAN is that you can change all the gauges to whatever you want and have some readings update at a higher priority.
If anyone's interested, I can post up the RR skin files and Skinbedder ini's after I'm done.
03-12-2006, 11:48 PM
#2
Cool, i wish I has an eval license to check out PCMSCAN.
03-28-2006, 12:16 PM
#3
The latest version of PCMSCAN is now a functional demo version. You'll be able to connect to your vehicle, detect supported parameters, and datalog Engine RPM.
04-07-2006, 10:12 AM
#4
PCMSCAN RR Skin
Hi Can you please email me the RR skins.
damiangoh@x-auto.com
thanks in advance
04-07-2006, 07:01 PM
#5
Cool !!!! Could i have the skins also  !!
VIA EPIA M10000 LVDS 1Ghz Motherboard,
256Ram,80Gig,
Lilliput 7" In Dash Touchscreen
Panasonic Slimline Slot-in Cdrw/dvd Player,
USB Gps Reciever,
Belkin Bluetooth dongle
Belkin USB wifi
Carnetix CNX-P1290 60W Power Regulator
04-07-2006, 07:08 PM
#6
How did you embed all the gauges ?
256Ram,80Gig,
USB Gps Reciever,
Belkin USB wifi
04-07-2006, 09:44 PM
#7
Same here. want it to.
Thanks.
04-07-2006, 11:12 PM
#8
donkeyboy,
what Front End are you using?
I cant really find one that I can have the OBD-2 fully integrated.
I just got my Karputer ICEPAC2 with a Lilliput Indash 7" touch screen with TV and FM.
But I got problems converting SPDIF 5.1 to RCA. I cant find a SPDIF in Amplifier.
Chronix
04-10-2006, 04:28 PM
#9
Hi am using road runner. I Like what sandworm has done and i am keen to try it out
256Ram,80Gig,
USB Gps Reciever,
Belkin USB wifi
04-14-2006, 02:01 AM
#10
PCMSCAN screens
Hi Sandmworm....
I would love to have the skins also... have you posted them anywhere yet? Thanks a million...
Joel
04-14-2006, 10:52 PM
#11
 yeah i would like the skin also.. i'll PM you now...
CAN'T WAIT!!
04-19-2006, 10:21 AM
#12
anyone has the files for this skin??? i'd relly like to use it with frodoplayer...
HEEELPPP
04-21-2006, 01:42 AM
#13
Sorry guys, I was away on business travel and there's a bug in skinbedder where it won't focus the app that's embedded in it. Pretty much this is a work in progress and is pending a solution with skinbedder. I've included the skinbedder ini files that are used to properly format the screen, the RR skins for the OBD2 Menu and an example RR menu.ini file to load the OBD2 Menu, but since there's no way of getting focus from roadrunner, I can't send the F2 necessary to begin the realtime monitoring in the gauges. Again, once the author of skinbedder fixes the focus problem, I can add that to the RR skin command.
P.S. The main skin is available here http://www.mp3car.com/vbulletin/rr-skins/47182-kuo-skin-release.html
edit: Actually, now that I've looked at it, sending the F2 isn't a problem (add {F2} to the end of each dash's sendkey command). The problem is when RR focuses skinbedder, skinbedder doesn't focus PCMSCAN, so if you want to change dashes or focus the app sometimes you have to tap the gauge area in order to get it to work. Otherwise, I haven't seen any major problems with it.
06-07-2006, 02:51 PM
#14
OBII hardware
what ODBII hardware are you all using with PMSCAN . .. i noticed that the speed of acquisition is dependent on your hardware scanner ...
96 cobra
suspension: MM CC plates, H&R super sport, bilsteins, steeda:bump steer kit, X2's, moly SFC's, triax shifter. MGW handle, cobra knob. Audio:RUX-C701, PXA-H701, MRV-F545, MRD-M1005, SIR-SC-H1, DMHD1000, Polk/Momo MMC6500, MM2104
08-21-2006, 04:26 AM
#15
Hi everyone, I'm new to RR/Skinbedder and have no clue how to implement the PCMScan-skin in RR. Can some one help me? I'm not new to computers so a pointer in the right direction is enough. Or is there another nice way to show the PCMScan OBD2-data/gauges on a small screen? (I don't want the window borders, they take up too much space)
//L
| Thread Tools |
| Display Modes |
Linear Mode
