Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 03-19-2006, 09:56 PM   #1
jmciver is on a distinguished road
CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
I just thought I would post my experience with the combo mentioned in the title since we are always looking for new ways to "skin the cat" in these forums....
Anyway, I purchased the CarPAL Bluetooth OBD II scan tool to complement my CarPC project. I went the BT route since I wanted to minimize the use of wires to the max extent possible for my CarPC project. That and the fact the the BT unit was not that much more expensive than the non-BT unit. Another nice thing about the BT unit is that it can easily be removed (and put in the glove box, etc) when it is not being used. I have not decided if I will leave it connected permanently or only when I want to use it, however since it is BT I am leaning strongly towards just leaving it connected permanently (but of course it is easy to remove if I needed to do so). The software that came with the CarPal unit is functional and performs as well as just about any other software out there, but I was not too impressed with the user interface, especially in a CarPC environment.
The Digimoto software looks better, has more features (I like the dyno feature and can't wait to try it) and is more suited to the CarPC environment IMHO (I am glad to see the company is up and running on all cylinders again). Even though it is not a very "skinable" software, when set to full screen on my Xenarc (whch is where I would run it anyway) it works very well.
I also took a bit of a chance since I could not get any confirmation that the Digimoto software would work with the CarPal hardware however since all of the OBDII stuff currently out now essentially uses the same protocalls & interfaces, it seemed like it should work. I got the Digimoto Lite software first and it worked. And as expected the full version of the Digimoto software worked as well .....
I have not done the final test for the combo since my CarPC is not installed in my car yet. However, the test that I did run with my car running in the garage and my CarPC running on the bench in the house (room above the garage) tells me I should have no problems once it is installed in the car.
jmciver is offline   Reply With Quote
Old 03-22-2006, 11:07 PM   #2
Bailey's Avatar
Bailey is on a distinguished road
Link please? I haven't seen a bluetooth one yet.
Bailey is offline   Reply With Quote
Old 03-22-2006, 11:47 PM   #3
Here you go.....
http://www.vitalengineering.co.uk/
Old 03-23-2006, 03:19 PM   #4
The6's Avatar
The6 is on a distinguished road
Do you know if Digimoto can be launched from within RoadRunner ?
The6 is offline   Reply With Quote
Old 03-23-2006, 03:27 PM   #5
pshadwick is on a distinguished road
You can using the launch command, Some skins have configurable buttons, you can set one of these up to launch digimoto (or most anything else).
pshadwick is offline   Reply With Quote
Old 03-23-2006, 09:05 PM   #6
I just use the launch command since the skin I am using in RR does not have a screen for Digimoto.
Old 06-16-2006, 05:08 PM   #7
digimotojoel is on a distinguished road
The developers at Digimoto are working on 5.0 which will be a free upgrade for all existing customers. I will also suggest that for future versions the software is modified to easily slide into other existing systems like RR etc.
Joel Konecny
Digimoto OBDII Diagnostics
digimotojoel is offline   Reply With Quote
need help finding good software simon_C MacCar 0 02-21-2005 10:27 PM
Going to Buy bluetooth GPS, Socket a good company? cyberdrakon GPS 2 10-26-2004 03:28 PM
Need good GPS software for Canada Bobby Digital GPS 7 02-11-2004 07:45 PM
is there a good touch screen friendly gps software? Rami GPS 8 02-03-2004 06:17 PM
What software is this??? It looks really good.... bankingdom Software & Software Development 7 06-30-2003 04:15 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
