Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 03-14-2009, 12:29 AM   #46
split63's Avatar
split63 is an unknown quantity at this point
Quote: Originally Posted by jyaron View Post
So in a MAP based calculation:
pseudoMAF= (IMAP/120)*(VE/100)*(ED)*(MM)/(R)
Therefore, if VE increases,.. pseudoMAF increases?
I thought the engine sucks less fuel if it has higher volumetric efficiency?
VE refers to how completely the cylinder can be filled with each intake stroke. Because of the restrictive nature of the intake path and the inertia of the air/fuel mixture, the cylinder can not fill completely before it begins its up stroke. So if it only filled with 80% of the air that it could have, it has a VE of 80%
The IMAP above is absolute. So if the engine can "suck" better, the IMAP would be less (more of a vacuum). So if we could adjust VE with a knob we might see that as VE increased, IMAP decreased. VE ^, IMAP V.
Furthermore, with increased VE, the throttle need not be opened as much, as the same air/fuel is needed, so perhaps the IMAP would decrease. Or may be its the same
VE is not a constant, it varies with RPM. Ignoring the potential harmonic effects, one would expect that as the RPM increases, the cylinders have less time to fill, hence the VE drops. As VE drops, IMAP would increase (less vacuum). But since RPM is increasing, there are more intake strokes per second to suck more air and hence IMAP may decrease.
Hell, ultimately I'm not sure if IMAP provides the compensation for variations in VE. Hence my question.
Has any come across a chart of VE versus IMAP. Though such a chart would likely be different for each engine design, a single chart would at least provide some insight into the relationship.
split63 is offline   Reply With Quote
Old 05-31-2009, 04:30 AM   #47
efun is an unknown quantity at this point
good project. thanks for share
efun is offline   Reply With Quote
Old 06-03-2009, 12:35 PM   #48
lightner's Avatar
lightner is an unknown quantity at this point
Been there...done that. As it turns out, this is a very "doable" project if you happen to have an OBD-II compliant vehicle with a MAF sensor---plus MAP, IAT and RPM sensors (almost 100% of OBD-II vehicles have these latter three). The MAF sensor gives you air-flow directly. The other parameters can be used to get a value that is directly proportional to volumetric efficiency (VE)---using the methods I've discusses earlier in this thread. The MAF sensor's "air flow" reading allows you to solve for VE. Then you can plot VE vs. RPM.
You will likely find that VE is in fact *not* a constant and does vary somewhat with RPM. And, depending upon the exact vehicle, the precise relationship between RPM and VE may be "complex", for all the reasons you discussed.
However, if you just want long-term MPG, you will find that using a constant for VE likely gives you a number that is "good enough". Part of the reason for this is that during "normal driving" a vehicle's engine is operated in a relatively narrow range of RPMs, and therefore with a more or less constant VE.
Best regards,
Bruce D. Lightner
lightner@lightner.net
http://www.lightner.net/lightner/bruce/
lightner is offline   Reply With Quote
Old 06-16-2009, 09:53 AM   #49
Keith55555 is an unknown quantity at this point
Available % of PIDs
If as Bruce says:..." MAP, IAT and RPM sensors (almost 100% of OBD-II vehicles have these latter three)" what percentage of OBD-II vehicles have these three PIDs available(I've learned that just because there's a sensor,doesn't mean there's a PID offered in some cases).-Keith
Keith55555 is offline   Reply With Quote
Old 06-16-2009, 10:52 AM   #50
Aberk is an unknown quantity at this point
Excluding IAT, I have not come across a car that did not support some combination of Speed, RPM, MAP or MAF so that Ii could compute MPG. I have only not found IAT on some 1997 and older vehicles.
Aberk is offline   Reply With Quote
Old 06-16-2009, 12:05 PM   #51
re:Available % of PIDs
Thanks Aberk,that's encouraging.
The last absence I have of information refers to something Bruce Lightner said early on,which is:
"As for other ways of doing this, especially if you don't have a MAF sensor, by knowing the displacement of the engine, and after a simple "calibration" using fuel tank "fill-up" data to find the only unknown, namely the "volumetric efficiency" (VE) of the engine..."
The "simple calibration" and "fill up data" as stated above is what's missing from my understanding. Thanks,Keith
Old 06-16-2009, 12:15 PM   #52
The fill up method is when you take your car to the gas station fill it to the top of the neck so that you can see the fuel and can fill it to the exact same spot again. Zero you tripmeter. At your next fill (preferably at the same pump) fill your tank to the same spot and record the tripmeter distance and fuel to fill the car. Divide the distance by the fuel and you have your average MPG. This next part will require fine tuning. Now that you know what you avg MPG is you can adjust the VE in your equation until you are recording the same AVG MPG with your OBD readings as you gathered from the fill method. This all relies heavily on driving habits and such, but the larger the data set you have to use, the more accurate your VE and MPG calculations will be.
Old 06-16-2009, 01:46 PM   #53
Got it,Aberk. And thanks. The one thing left ,making me scratch my head is; devices like the Kiwi and Scangauge, as far as I know, are 'plug and play' without this 'calibration' using the 'fill up' data. They read cars without MAFs,I assume using the MAP data,etc.
Do you think they are using some form of an average MPG as indicated by the manufacturer in place of the fill up method? Thanks,Again,Keith
Old 06-16-2009, 02:08 PM   #54
They either have an equation that attempts to calculate a VE from other inputs or they assume one. I dont have much experience with the Kiwi, but the SC II is very user involved. The SC II is plug and play for reporting instantaneous MPG. I know the SC II gets more accurate as you use it correctly with fillups and by inputing engine displacement and fuel tank size, so I assume it is logging this data to make this possible.
Old 07-08-2009, 03:35 PM   #55
lightner's Avatar
How to "calibrate" OBD-II derived MPG when using IMAP
"Plug-and-play" MPG calculation from OBD-II bus parameters is not out of the question for many vehicles---not just MAF-equipped ones. It all depends upon what is available on the OBD bus---from legally mandated OBD-II parameters (i.e., "emissions-related") and the much richer set of manufacturer-specific OBD parameters. Here are some things to consider if a MPG device wanted to make "guesses" about your non-MAF vehicle's engine and gas tank and then "plug-and-play" using IMAP data...without initial user input:
(1) Read the VIN (now a legally mandated OBD-II parameter). With "VIN decoder" firmware (a non-trivial, moving target in itself) one technically can find engine type and displacement, and even fuel tank capacity---as well as paint color!? :-)
(2) Monitor the fuel tank level (now a legally mandated OBD-II parameter). For many vehicles, old and new, this parameter can be read as a manufacturer-specific OBD PID. Knowing (or guessing) the fuel tank capacity, over time (watching for "fill-ups") this can give you what you need to calculate MPG---despite the well known non-linearity of everyone's fuel gauge!
(3) Count the number of O2 sensors and make a guess about the engine displacement and/or fuel tank capacity (e.g., V8 engines have more O2 sensors).
I have some more, but this kind of stuff is potentially valuable, as more and more States---and even the Federal Gov'ment---are looking at a direct "road tax" on our driving. Why? Because per-gallon fuel tax receipts are dropping, as more high-MPG vehicles (e.g., hybrids) hit the road. For example, our friendly government "overlords" need some way to calculate mile-by-mile fuel consumption so that the per-gallon fuel taxes somehow can be refunded to "Big Brother Box" equipped vehicle owners! :-)
Old 09-21-2009, 01:07 PM   #56
VegasGuy's Avatar
VegasGuy is on a distinguished road
Help with formula...
I started with this formula:
MPG = (14.7 * 6.17 * 454 * VSS * 0.621371) / (3600 * MAF / 100)
= 710.7 * VSS / MAF
MPG - miles per gallon
14.7 grams of air to 1 gram of gasoline - ideal air/fuel ratio
6.17 pounds per gallon - density of gasoline
454 grams per pound - conversion
VSS - vehicle speed in kilometers per hour
0.621371 miles per hour/kilometers per hour - conversion
3600 seconds per hour - conversion
MAF - mass air flow rate in 100 grams per second
100 - to correct MAF to give grams per second
Then I realized that Centrafuse return Miles Per Hour for VSS and Cubic Feet Minute for MAF, so I would assumed that in order to correct this formula it would look like this:
MPG = (14.7 * 6.17 * 454 * VSS) / (60 * MAF)
= 686.2891 * VSS / MAF
Eliminates Kilometer conversion
Changes 3600 to 60 since MAF is already calculated to minute rather than second
Eliminates 100 grams calculation
The problem is, the reported results are slightly HIGHER than I would have expected. The original formula without modification produced instant and average milage figures pretty close to what I've seen from other products. The new formula, modiified to take the CentraFuse values into account, produces milage figures slightly higher than before.
Not unreasonable, mind you, but what i would say is at the upper bounds of reliability.
So what am I missing? I think it must be in the MAF calculation, but I'm not sure how to convert between grams per second and feet per minute.
[EDIT]
If I multiply MAF by 0.0807 , that gives me pounds per minute. Then if I multiply by 453.59237, I get grams per minute. Could this be the answer?
Thoughts?
VegasGuy
VegasGuy is offline   Reply With Quote
Old 09-21-2009, 01:26 PM   #57
Rooster is an unknown quantity at this point
I'm not sure what Centrafuse reports, but if it reports MAF in Cubic Feet per minute, that is a volumetric flow not a mass flow. That seems a little strange?
Rooster is offline   Reply With Quote
Old 09-21-2009, 01:52 PM   #58
VegasGuy's Avatar
Strange, but true
i just went out and looked, and Centrafuse is definitely reporting CFM. 340CFM at idle to be precise.
My idea about converting cubic feet to pounds and then grams doesn't produce the correct values either.
I'm stumped.
Old 09-21-2009, 04:19 PM   #59
split63's Avatar
Has anyone ever come across any details regarding any manufacturer specific PIDs? You would think that after all this time, details would have leaked out.
Old 09-21-2009, 06:44 PM   #60
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
There was a thread on here with some decent info for Ford vehicles, but it disappeared a while back.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
