Quote: Originally Posted by
VegasGuy
i just went out and looked, and Centrafuse is definitely reporting CFM. 340CFM at idle to be precise.
My idea about converting cubic feet to pounds and then grams doesn't produce the correct values either.
I'm stumped.
Yeah, come to think of it carburetors are rated in CFM so I guess it might make sense to show a value of CFM.
They are probably using the 'ideal gas law' pV = nRT to convert the mass into a volume, so you would have to do the same type of conversion but in the reverse direction. The value for 'R' is a constant but depends upon the gas. Maybe you could wiggle that value to get your calcs to come out?
