Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 04-27-2006, 07:51 AM   #1
ECU Remapping
I just got the ecu flasher and a software to remap the ecu on my Hyundai Accent crdi 2006 model. I just wanna ask do i need to buy new remappable ecu or original ecu can be remapped. I know thats a silly ques but i new to this field.
agrawal_nipun is offline   Reply With Quote
Old 04-27-2006, 10:18 AM   #2
goosey2099's Avatar
If you can ask this question then you REALLY shouldn't be playing with ecu flashers or anything of this nature. Search/Real/Learn!!!!
4G64 5 SPEED
MY CAR - MY 5SPD - MY CARPUTER - MY GARAGE SALE
goosey2099 is offline   Reply With Quote
Old 04-27-2006, 01:36 PM   #3
Thanks but guiding me, but i still have same query in my mind. Advice taken but plz clear my query.
Old 04-27-2006, 03:35 PM   #4
goosey2099's Avatar
You should first ask the guys that sold the equipment to you if can be done with a stock ecu. But most likely from my experience of dealing with mitsubishi every ecu can now be reflashed. Just be very carefull with what you're doing. What engine mods do you have that makes you want to remap it?
4G64 5 SPEED
Old 04-28-2006, 02:49 AM   #5
thanks for help
Old 04-28-2006, 06:29 AM   #6
Sounds like this guy will at best end up with a dead ecu and non starting car or at worst blow up his engine.
ElKeeed is offline   Reply With Quote
Old 06-06-2006, 07:58 PM   #7
goosey2099's Avatar
I don't know about that guy but i just got the openecu ecuflash cable from mynes and allthough it doesn't work with my current ecu it will soon. I think the have some stuff for the mini cooper as well. http://www.mynesperformance.com/shop...products_id=66
4G64 5 SPEED
ECU Remapping - Digiflash? jazman27 Engine Management, OBD-II, Engine Diagnostics, etc. 2 08-23-2006 12:27 PM
OBDII read and programming ECU johnwrx Engine Management, OBD-II, Engine Diagnostics, etc. 1 11-11-2005 09:48 PM
Help me on Sagem SL 96 ECU pashe007 Engine Management, OBD-II, Engine Diagnostics, etc. 0 02-26-2005 05:55 AM
ECU to Car PC problem. cas850 Engine Management, OBD-II, Engine Diagnostics, etc. 4 12-23-2004 01:15 AM
ECU Programming/Tuning swzine Engine Management, OBD-II, Engine Diagnostics, etc. 1 11-16-2003 07:55 AM
