Quote: Originally Posted by
joeyoravec
Technically it's not polled -- you setup a request and the controller spews data continuously. From what I've seen Ford and GM support this on all OBD controllers back to 1995. Life was easy because they maintained tight control over the engineering process. But your mileage may vary and you'll always find exceptions!
Hi Joey,
could you elaborate on how this is setup for GM vehicles? I was'nt aware that this could be done, and I am curious on how you would do this? Is it just a CAN/Class II message and are you able to reveal what it is?
What software would you use with the Mongoose today to do this? and if no existing software does this do you have the API that someone could use to submit a bunch of sensor data to be streamed?
Paul
