The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 09-16-2006, 05:02 PM   #1
My Photos: (0)
MPG Computer for 94 GM ALDL
I suppose there are no miles per gallon software for obd1? I found one for eec-vi ford but they want $500.
Jammer is offline   Reply With Quote
Sponsored Links
Old 09-16-2006, 11:47 PM   #2
84RegalRider's Avatar
Vehicle: 1991 Lincoln Towncar
My Photos: (16)
nope
Core duo
320gb harddrive
256 ddr
8 lilliput
still installing...
84RegalRider is offline   Reply With Quote
Old 09-17-2006, 09:40 PM   #3
Vehicle: 96 Pontiac Trans Am
My Photos: (0)
I'm not sure how an OBD1 computer could do it, they don't really know how much fuel they are using. Some might be able to do it...but there lies the issue, there was no standard back then so it would need to be made just for that PCM.
96TransAm is offline   Reply With Quote
Old 09-18-2006, 01:50 AM   #4
My Photos: (0)
If your car is General Motors, the ECM makes "injector on time" available over the serial data line. If you can somehow tap into this and read it, you can calculate fuel used. I don't know for sure, but I believe that people have hacked into the signals sent over the serial line for GM cars.
The parameter is called "injector on time" and it tells you how long, in milliseconds, the computer is turning on the injectors. Each injector is rated in pounds per hour of fuel used. This gives you the info to calculate the amount of fuel being burned by the engine. It should be very accurate!
star-art is offline   Reply With Quote
Old 09-18-2006, 08:29 AM   #5
My Photos: (0)
That would require home made software over a ADL cable.
I'll ask around on the fbody boards, if it can be done on a fbody good chance you can do it on other GM cars as well.
Old 09-18-2006, 02:50 PM   #6
My Photos: (16)
eh i got HomeMade software for ALDL cable.
if you could tell me what byte it is should be no problem.
Core duo
320gb harddrive
256 ddr
8 lilliput
still installing...
Old 09-18-2006, 03:51 PM   #7
My Photos: (0)
Sorry, I have no idea. I just know the ECM reports the data, but I don't have any other specifics as to exactly how. . .
Old 09-18-2006, 03:57 PM   #8
My Photos: (0)
See if your car is supported by TTS Datamaster, load it up and take a look at the injector duty cycles, that might get you started on figuring it out.
Old 09-23-2006, 10:10 AM   #9
Vehicle: 94 Chevrolet Camaro Z28
My Photos: (0)
In base my design foy my camaro ODB1 on this winner project on the circuit cellar website.
http://www.circuitcellar.com/avr2004...05abstract.pdf
You can read the full description on :
http://www.circuitcellar.com/adverti...ghtner-183.pdf
MaZinGeR is offline   Reply With Quote
Old 09-23-2006, 12:16 PM   #10
Vehicle: 2003 Impala 9C1
My Photos: (0)
check out DIY-EFI
As for MPG, why not use a 94 era DIC? I had a 94 grand prix sedan that had a DIC and calculated MPG, range, etc etc. I do not have the DIC anymore, but I'm sure you could find one on ebay or junkyard for ~$20
Mad Jad is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Cutting power to USB after computer has shutdown lookinco Power Supplies 61 05-17-2006 01:05 PM
Computer becomes unresponsive, inverter problem? tsb4k Power Supplies 9 10-23-2005 02:22 PM
Making a Car Computer; Need Your Help! Fear Effect Newbie 17 10-20-2004 04:49 AM
computer theft tracking - PC PhoneHome Question General MP3Car Discussion 9 07-16-2003 02:14 PM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 01:42 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
