02-20-2007, 10:55 AM
#136
I would like to test it, i have a 1999 jeep cherokee. Please PM me with more details. THanks paul
02-20-2007, 07:20 PM
#137
I don't know if any european cars have been tested yet.
DOn't even know if it wil work. But if it does than Im intressted.
I have a 1997 peuogeot 306.
02-21-2007, 09:55 AM
#138
VENDOR - OBDPros
We have a number of folks using the interface in EU but I believe the 97 Peuogeot is not OBD II
The Beta test was started around 4 months back and now we have moved into production.
Paul
www.obdpros.com
03-12-2007, 02:34 AM
#139
I test it
I have a 2004 BMW 530I E60.
I am highly interested with software.
I have diagnostic software but looking to do data log and remaps.
PM me with the details i can do this asap.
Rito
03-12-2007, 03:14 PM
#140
Paul, you are absolutely correct - the Peugeot is not OBD2 compliant.
Gareth
04-15-2007, 01:51 PM
#141
Paul,
I have the 2003 Toyota Camry LE, 2002 Toyota Sienna, and 2001 Subaru Forester. Is your OBDPRO will work with all my vehicle? There is OBD wireless version out there. Would it work if add a bluetooth wireless adaptor to your OBDPRO? Is there a list of beta test result available online with your scanner?
04-15-2007, 03:48 PM
#142
I have a Citroen C3 from 2003,
I am quite sure that the scantool will work,
but it would be nice if you could confirm.
and please,
I have bought a KWP2000 reader/writer off Ebay,
and that damn thing can't do S***
until now, I have only one program that can use the thing (it is a USB edition)
and that program is KWP2000.
I was hoping that the KWP2000 could read out engine data (OBD informations)
but haven't found any programs that supports the damn thing yet, with those possibilities.
you write that the scantool supports
ISO, KWP2000, and a bunch of more protocols.
does this mean that I would be able to throw away the KWP2000 reader, and use your tool instead, and be able to do the exact same stuff, such as program the ECU..?
Sorry for the english
CarPC Specs.
Via Epia MII 12000 \\ 512 Mb Ram \\ 200 GB Western Digital \\ PCmcia asus wi-fi
Xenarc 7" Touchscreen \\ Usb Bluetooth \\ Carnetix P-1280
04-16-2007, 08:15 PM
#143
VENDOR - OBDPros
and please,
Hi Mcnovy,
The OBPro does support KWP2000 but it would only be able to show the OBD II data, it will not be able to program the ECU though.
As far as support for the Citroen C3, If you can identify the what pins you have on the OBD II connector in your vehicle based on this link
http://www.auterraweb.com/obdiipinout.html
You can pretty much be assured that the OBDPro will work.
Paul
www.obdpros.com
04-26-2007, 06:23 AM
#144
i am very interested of that will how can i purchase that?
04-26-2007, 06:51 AM
#145
pls sir i am very very very intesested of that obd and i really need that thanks.....
04-27-2007, 09:19 AM
#146
VENDOR - OBDPros
Hi Coneair,
Just go to www.obdpros.com and you can order the scantool from there.
Paul
www.obdpros.com
05-27-2007, 09:39 PM
#147
I've done a quick search, but couldn't find an answer. I thought I read something a while ago where someeone was saying that you can't use a serial to usb converter with the scantools? Ie. Using a serial scantool with a converter into a usb port. Am I making this up or is it possible?
I bough the serial tool a few months back, my system has changed lisghtly and the abaility to use usb would make things MUCH easier.
I installed my carpc into my pet Kangaroo, mate.
05-28-2007, 12:12 AM
#148
You should be able to use your USB to serial adapter. I believe it is preferred that you buy the USB version if you need to plug it into a USB port, but there is no reason why you cannot use a USB to serial converter with your existing serial device.
-Brian
05-28-2007, 03:06 AM
#149
Software Recommendations?
Paul,
Your web site says that you can monitor the network traffic, send messages to vehicle modules and read your vehicles "brain". I'm new to this but I thought most of that would be software driven.
What I'm interested in is the ability to read some non standard PID's specific to the 08 Fords. Can you tell me what software will permit me to use your tool to it's fullest?
Regards,
Dan
Real world knowledge isn't dropped from a parachute in the sky but rather acquired in tiny increments from a variety of sources including panic and curiosity.
05-28-2007, 08:50 PM
#150
VENDOR - OBDPros
Quote: Originally Posted by DM2
Paul,
Regards,
Dan
Hi Dan,
Unfortunately reading non standard pid's is not supported by most of the software sites available for the OBDPro interface. If you know the non standard pid's I would love to work with you to add those to a software package.
I know autotap and autoengenuity have support for non standard ford pid's but the pid's supported vary and there is no guarantee that you would get what you need as far as non standard pid's are concerned.
Paul
www.obdpros.com
| Thread Tools |
| Display Modes |
Linear Mode
