Quote: Originally Posted by
dieselray
@joeyoravec: pin 2 is an "SAE +" communication line, which requires pin 10 ( SAE - ) as this is a twisted pair network. Pin 7 is the ISO K line which allows Global OBD-II communication across a multiplexing single wire network. Emissions tests require access to the OBD-II readiness monitors, this is done over the SAE lines.
Although you dug-up an almost two-year-old thread it's worth correcting your correction. You may be confused between the two variations of J1850. Ford implements J1850PWM which uses differential signaling so it needs both pin2 (J1850+) and pin 10 (J1850-). General Motors, Chrysler and anybody else implements J1850VPW which is single-ended and needs only pin2 (J1850+). The original poster asked about a 2000 Chevy S10 which uses J1850VPW so the information in my original post is correct.
dieselray
I have never seen a PCM or any other module share the same circuit as a cigarette lighter, ever. No manufacturer would open themselves to the liability of having a major system fail because a customer plugged in some garbage 12v accessory from jc whitney & blew a fuse!
Perhaps I was not clear. The PCM is obviously powered if the vehicle runs; what I meant to question was the diagnostic connector and wiring. It's common for the OBD-II connector to share a fuse with something else and it's very easy to overlook a defective power, ground, or communication line if your scantool gets power from batteries or the PC's USB port.
Whenever you think to yourself "this should work" then it's important to drop back to the basics. Does the same scantool work on a different car? Does a different scantool work on the same car? Is the scantool powered and grounded? Is the scantool configured correctly for this car? Is the OBD-II connector damaged? Is the wiring between the diagnostic connector and the PCM intact? Work through some easy-to-verify tests and eventually you should isolate the problem.
The only additional suggestion I'd make today is to check the grounding scheme. The vehicle is
supposed to have pin4 and pin5 for ground. Many vehicles ground both, but what if the vehicle grounds one pin while the scantool relies on the other. Checking that your scantool is actually powered and grounded is important when you have a mystery like that.
dieselray
Myself speaking as an automotive technician, I recommend your son take the car to a GM dealership. They are the ones who will have the Tech-II scanner, the GM information system (diagrams), O-scope, & the expertise.
Speaking as an engineer that designs service tools I have to agree. Lots of things require specialized tools and aren't worth the time, money, or effort to do yourself. It's important to have a trustworthy shop that can take care of the vehicle.
