Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 04-27-2009, 03:37 AM   #46
ElCap's Avatar
ElCap is on a distinguished road
Quote: Originally Posted by malcom2073 View Post
That's the aussie version of mine, which is the 1227165, cept you don't have 8192 baud you're limited to 160 baud. In theory it has the same datastream output as mine in 160 baud mode (mine does both baud rates), but you're gonna be limited in update rate.
Yeh stupid 160 baud rate! ive heard that i can replace my 1227808 with the 1227165 and get the 8192 baud rate. but i cant seem to find any for a good price. ive also got a kalmaker tune so i'd prob need to check with my tuner that it would be a straight swap (cant see why not..).
160 baud rate just aint enough for any proper digital dash thou.. i mean it can display a fair few things like battery voltage, water temp etc (stuff that doesn't change too often) but for anything that update regularly (like speed, tacho, tps etc) its not too practical.
but hey ill still give a go lol.
ElCap is offline   Reply With Quote
Old 04-27-2009, 09:34 AM   #47
talons24 is an unknown quantity at this point
There is a website out there that might help you find the other ECM for a more reasonable cost it is CAR-PARTS........ You can search by price or how close they are to you. Thats where I got my ECMs.
talons24 is offline   Reply With Quote
Old 04-28-2009, 08:46 PM   #48
davesaudio2
Each ECM using a different protocol, ya gotta wonder just what they were thinking. Different teams I suppose...
davesaudio2 is offline   Reply With Quote
Old 05-10-2009, 03:57 PM   #49
84RegalRider's Avatar
84RegalRider is on a distinguished road
"160 baud rate just aint enough for any proper digital dash thou"
agreed, even though it was only less then a second lag i got it down too it still kinda sucked, but thats only when i floored it. Under normal driving everything was updated regularly and on time.
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
84RegalRider is offline   Reply With Quote
Old 07-02-2009, 10:07 AM   #50
antus is an unknown quantity at this point
Ive just signed up here to post some info for ELcap. Kalmaker runs 8192baud ALDL, not 160. To get this data you'll need to add a max232 serial interface to your ECU. This serial link will differ from the 'real' 8192 baud ALDL in that it wont be on the ALDL pin on the OBD connector, instead after modding your ECU you'll have a full duplex serial port. Assuming you have a street pro 3 tune, not workshop, and if it is the normally aspirated program (N03) you can get a definition for scannerpro or tunerproRT 5 (when its released) here:
http://www.delcohacking.net/forums/v....php?f=10&t=29
Ive also developed some ALDL software that emulates a moates autoprom to talk to tunerproRT and converts the write requests to Kalmaker or OSE ALDL write requests (when running on NVSRAM). This software is called antusprom. Im having some trouble getting it to talk reliably to newer PCMs though, and it has no gui, so I hope to try and improve some of the software in this thread instead.
Does anyone know if the source for the QT toolkit ALDL reader here is available?
antus is offline   Reply With Quote
Old 07-03-2009, 12:09 PM   #51
update: its been suggested that kalmaker runs 160baud as well as 8192, but naturally 8192 is the way to go.
Old 07-04-2009, 06:43 AM   #52
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
Antus: I wrote it, and I'll stick it up on sourceforge sometime this weekend.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 07-04-2009, 07:59 PM   #53
too bad i dont have a GM car anymore. My programming knowledge has come a bit farther in the 3 years since i wrote my program.
lol
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
Old 07-04-2009, 10:12 PM   #54
cool, i'll keep an eye out for it
Old 07-09-2009, 08:43 PM   #55
ElCap's Avatar
Ok cool, so i can run 8192baud with my kalmaker tune.
so what ur saying is that instead of getting an ecu that outputs 8192, that i can add a serial interface to the ecu and use that to get my obd data?
Not sure if its a street pro3 tune... any way to check?
Its a supercharged engine so its not an n/a program.
Thanks for the info thou! ill have to do some more searching and reading.
Rob
Edit: fyi, i dont want to tune my car, just show the obd data.
Old 07-09-2009, 08:49 PM   #56
antus: The program is on a computer I don't have access to, so it's gonna have to wait a while.
Old 07-09-2009, 08:57 PM   #57
You'll need to do the comms mod to the ecu hardware, that is add a max232 chip to give you a serial interface. I cant find anywhere that this mod is documented on the net, although its quite common. I'll take some clear shots of mine tonight and document what pin is what. The VR manual code ($12) will also run on the '808 and give high speed comms with this mod, and delcohacking.net has a modified version of this with wideband support and nvram write (realtime editing!)
Old 07-09-2009, 10:03 PM   #58
ElCap's Avatar
cool thanks antus!
Old 07-13-2009, 08:33 AM   #59
Heres the delco '808 comms mod. This gives you an 8192 baud serial link, with _no echo_. Most ALDL cables do echo, so depending on the software you use you may need to find the echo setting and turn it off.
OSE (based on $12 code, available free from delcohacking.net) or kalmaker street pro 3 code will log with this mod.
you need the standard caps for a max232 as well
Old 07-21-2009, 08:43 PM   #60
ElCap's Avatar
hey antus,
thanks for the pic, however im not sure if i follow correctly.....
so i need to add a max232 chip and then connect +5v,gnd,r1 out, t1 in; from the ecu to the corresponding pin on the chip.
and then from the chip i connect pin 2,3,5 to 14,13,15 respectively on the db9 serial cable?
Rob
Edit: i noticed u mentioned adding caps.
i did a bit of a google for max232 and got a few diagrams.
one uses 1uf caps and the other uses 10uf.
do u know the values, or doesnt it matter too much?
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 02:06 AM
delorme software replacement? fortressgame GPS 20 11-10-2005 08:48 AM
WTB - Iguidance or OBD software gdawg Classified Archive 4 09-20-2005 08:43 PM
Software solution for gLCD-based car-mp3 Novgorod Software & Software Development 1 07-01-2004 08:59 PM
myHTPC Software the_new_guy Software & Software Development 1 06-05-2004 04:51 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
