Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 11-12-2006, 08:23 AM   #1
Is there OBD Connector in my Car?
My car is Hyundai Elantra with a-CVVT engin,Made in 2006.Is there OBD connector in it?and How can I know where it is?
Could somebody take some photos?
guodl is offline   Reply With Quote
Old 11-13-2006, 02:42 AM   #2
Hi,
You will have an OBD2 connector, it has to be within 2 foot of the steering wheel, and easily accessible. They are often covered with a clip off cover, or could be under the dashboard - have a nose about. You are looking for a rectangular plug that looks like this.
Being 2006 you need to also bear in mind that your car is also probably using the CAN protocol.
Good Luck!
Gareth
UKOBD is offline   Reply With Quote
Old 11-13-2006, 04:01 AM   #3
Fusion Brain Creator
2k1Toaster's Avatar
Yup, you have one. All above '96 (I think) have it. Must be within a meter of the steering column like UKOBD said. Sometimes you must remove a few panels to get there, but it should be "easily accessable" as per the standard.
Old 01-17-2007, 06:05 AM   #4
How to analyze OBD msg ?
Hi,
Can someone tell me how do i analyze the OBD information recieved from ECU?
I am using CAN interface and i need to analyse the different data (DTC, Freeze frame ..) and display the recieved information using display interface.
So how do i analyse different types of data recieved from ECU ?
Ambika is offline   Reply With Quote
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
Hardwired OBD scanner and motor vehicle inspections 01black_ac Engine Management, OBD-II, Engine Diagnostics, etc. 4 04-29-2006 11:40 PM
OBD 1 Diagnostics software? MaleBuffy Engine Management, OBD-II, Engine Diagnostics, etc. 3 06-13-2005 07:05 PM
OBD Diagnostics connected all the time? Zoltan Engine Management, OBD-II, Engine Diagnostics, etc. 7 08-23-2004 02:47 PM
OBD USB or LPT1 Connectors? Ritalin Kid General Hardware Discussion 11 09-19-2003 10:01 PM
