The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 11-25-2006, 10:53 AM   #1
My Photos: (0)
P0441 Error
I used OBDPros and the result was
P0441 : Evaporative Emission Control System Incorrect
Purge Flow
can anyone tell what can I do?
antilife is offline   Reply With Quote
Sponsored Links
Old 11-25-2006, 12:50 PM   #2
Cheekz185's CarPC Specs
Vehicle: 2002 Mitsubishi Galant
My Photos: (0)
Do you have a VW?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 11-25-2006, 04:37 PM   #3
My Photos: (0)
something as simple as a loose gas cap could cause this, but as cheekz185 mentioned knowing the make model year or your vehicle might help narrow down the possibilities
michbound is offline   Reply With Quote
Old 11-26-2006, 09:25 AM   #4
My Photos: (0)
my girlfriends '99 VW Passat had the same error code. I figured out where the problem was coming from. its called a purge valve.
This is what it looks like:
It is located in the engine bay near the airbox/air filter. Very easy to replace!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 11-27-2006, 07:40 AM   #5
My Photos: (0)
I didn't expect to have that quick response, Thanks guys.
My car is Eclipse 02 4 Cylinder, and sometimes check engine comes up and go back. I didn't see anycrash around the gas cap.
you suggest me to change the gas cap. and purge valve.
If I'm running my car, it does't damage it.
Old 11-27-2006, 07:53 AM   #6
My Photos: (0)
i have an 02 Galant.... We have the same engine and chassis. Try tightening your gas cap...My check engine light comes on when it is not tight enough!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 11-27-2006, 08:06 AM   #7
My Photos: (0)
thanks, I will try it. hopefuly it works.
Old 11-27-2006, 08:08 AM   #8
My Photos: (0)
and beside that, on my ford turus 98, I have p0156 , what can be wrong with it.
Old 11-27-2006, 08:10 AM   #9
shotgunefx's Avatar
Vehicle: 2002 Chrysler Sebring Coupe LXI
My Photos: (33)
I've got an 02 Sebring Coupe which is also on the same platform, probably the gas cap.
As an aside, list of OBDII codes for the 2.4 and 3.0s can be found here.
Also, somewhere on club3g.com, there is a link to an online version of the eclipse factory service manuals, complete with pics and diagnostic procedures .
shotgunefx is offline   Reply With Quote
Old 11-27-2006, 12:36 PM   #10
My Photos: (0)
I think that's your 02 sensor, those are pretty easy to replace once you locate them, I would check at alldata online they should have a detailed description of the error code with a location for the sensor. I am pretty sure that it's an o2 sensor but do not know what the exact location is on your vehicle.
Paul
www.obdpros.com
Sponsored Links
Old 11-27-2006, 02:04 PM   #11
My Photos: (0)
first of all AAA+++ for OBDPro.com because of it's excellent hardware, I bought from them couple days ago. (( I didn't these check engine by that hardware ))
I did tight up the gas cap, and indeed it work and now I don't have check engine lit on. Thanks guys.
But for ford I don't know what I have to do exactly ?
Old 11-27-2006, 07:41 PM   #12
My Photos: (0)
Thank you for your kind words, I love it when people like our products...
Re the ford, your error code indicates that it is a bad 02 sensor, but I am not sure on where your sensor is located on the vehicle. googling for the error code shows this discussion
http://www.f150online.com/forums/arc...hp/t-4667.html
I would talk to a local murrays auto store and they should be able to help you identify the location of the 02 sensor on your vehicle.
Paul
Sponsored Links
Trackbacks are Off
Error -2147024770 and Error 91 inside RR Pistolen08 MM Bugs 4 04-02-2007 04:15 AM
Error 458, followed by error 91 each time any action is taken antonio_riq MM Bugs 1 01-03-2006 12:17 PM
Whats up with Geiss? Was working before but not now? PDiddy Centrafuse 7 07-01-2005 03:29 PM
ME 2.0 Official Bug Reports phat_bastard ME Archive 67 01-31-2004 06:27 PM
Error #91 SiGmA_X ME Archive 18 01-08-2004 09:40 PM
Sponsored Links
Ad Management by RedTyger
