Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 11-27-2006, 02:17 AM   #1
portabuddy's Avatar
ELM327 -> '06 civic Si ??yes...no?
befor getting a OBDII i decided to do a bit of reading then i found out that the 327 that is faster and has a better capacity might just work with my new car. i asked the seller on ebay if they had experiance with them and he said that one of the cars tested was the 06 civic.
now i'm usinf digimoto with the bit rate set and the port selected and all the info i get is the vin and thats it, my carputer isnt quite done but after i installed my exhaust im getting tired of the eng. light staying on and wanted to test the guages and other toys as well as clear the codes(o2 sensor error??i think )
my question is what do i have to do to get it to work, is there a specal way to do things like turn the key on then off the start the car connect pump the gass and spin around three times? or what? can some one please help...
ps im not normaly so dumb sounding. thanks.
Life Dosn't come with a reset button, if it did you might as well turn the game off.
portabuddy is offline   Reply With Quote
Old 11-27-2006, 02:28 AM   #2
portabuddy's Avatar
oh and i forgot to mention that the device works well my buddy used it to diaglose his car but that was a vw, and mine is a honda and i think that there has to be some kind of procedure to get it going.
Old 11-27-2006, 08:51 AM   #3
It sounds like you are using the Digimoto 5.0 beta from what you described. Does your 06 have multiple ECUs? You should know that we just released an update to our beta yesterday (rev 14) which has multiple ECU support for the ELM interface, you should download this latest update and give it a try.
http://forums.digimoto.com/shwmessag...MessageID=3045
Joel Konecny
Digimoto OBDII Diagnostics
digimotojoel is offline   Reply With Quote
Old 11-27-2006, 01:42 PM   #4
portabuddy's Avatar
eaven though i didnt have much sucess with your program working for me i like the useabilty of it and i would like to stay with it(since i already bought it ) and this the multiple ecm's thing dose make sense i will try the update a bit later, do you yourself or anyone else have any exp. with the 06 civics? and how to read the info???, just because i have used some freewhare that didnt work either.
Old 11-27-2006, 01:51 PM   #5
I am fairly confident the vehicle contains multiple ECUs (someone on the board can correct me if I am wrong). The data coming back also suggests that the software was only communicating with one ECU (partial data). I would be surprised if this update did not provide full access to your vehicles information.
Joel Konecny
Old 11-27-2006, 06:22 PM   #6
portabuddy's Avatar
Great now im going to go home at 12:00am download it and get ti installed on my laptop and play with my car untill 4:00am, you see what you did...just kidding thanks alot, and you are right threre are three that i know uf, the VECU(inside on the passenger side) LECM(in the dash) and the ECM(under the hood) and i think that it was communicating with the VECU(vehical-electronic.c.u.) insted of the ECU(engine controle unit). but now that the problem is solved thats good. also is there a way i can make a new guage skin? i want them to look like the ones in my car. if its not done jet can you please make the guage a seperate file that i can manipulate myself in the next beta version.
Old 11-28-2006, 02:29 AM   #7
tolisn's Avatar
Hi.
I tried installing the above mentioned trial software but I keep gettting errors when I try to register it as a trial version. It says that the serial number is incorrect. Any help would be deeply appreciated
The road is long but we are getting there.
tolisn is online now   Reply With Quote
Old 11-28-2006, 10:01 AM   #8
We are currently running as a closed beta, which means existing customers are being given license keys to test with. We will move into an open beta shortly with the application at which time everyone will be able to use it (in trial or licensed mode).
Joel Konecny
Old 11-28-2006, 01:10 PM   #9
tolisn's Avatar
oh. Ok. thanks for the reply
Old 06-21-2007, 12:46 AM   #10
erie's Avatar
portabuddy,
Did you ever get access to all the systems in your Si?
06 Galaxy Gray Si #0308
CarPc Progress -
10%---------50%---------100%
-[XXXXXXXXXXXXXXXXXXXXXX]-
erie is offline   Reply With Quote
Old 06-21-2007, 01:02 AM   #11
portabuddy's Avatar
ummmmmmm no, i was waiting for the new version of the digimoto to come out, then i forgot, and fixed my o2 sensor problem by extending the second sensor out further and now i dont get any codes ^_^... but i might look into it further now.
Having no cat does screw things up a bit. i did however clear my buddies codes several times...psssss. VW's eh. i dont even have my screen done yet.
06 Honda Civic EX Firewall breakthrough nevid77 Car Audio 8 02-24-2007 09:55 AM
carputer on civic 06 HeLLz aNgeL General MP3Car Discussion 11 02-12-2007 10:18 AM
Custom Dash with 700TSV for 02+ Honda Civic Si xmadcowx Classified Archive 3 09-06-2005 10:12 PM
1999 Honda Civic SI HondaPuter Chris732 Show off your project 12 08-11-2005 10:37 PM
anyone tried an install on a 03 Civic Si? Cheech Newbie 1 03-19-2005 07:19 PM
