The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 11-30-2006, 04:23 PM   #1
My Photos: (0)
Ford J1850 PWM
I am trying to build my own OBD-II reader using a PIC. So far I am able to connect to ISO9141-2 and J1850 VPW but am having some trouble with J1850 PWM.
When I send the J1850 PWM message, I cannot get an answer. I have put a scope on Pin 2 and Pin 10 and see the message go out and also a 1 byte IFR being returned from the vehicle approx. 40 us after my message. But no other message is returned from the vehicle.
For example, I transmit 0x61 0x6a 0xf1 0x01 0x00 0x0a which is supposed to read the supported PIDs of the vehicle. All I get back is a 1 byte IFR of 0x1f.
Does anybody know if I am supposed to transmit again after the 1 byte IFR or am I doing something else wrong?
So far, I am using only information that I have found on the internet, such as obddiagnostics.com
Thanks for your help.
plisskin is offline   Reply With Quote
Sponsored Links
Old 12-01-2006, 08:09 AM   #2
My Photos: (0)
Arrgh, it was my own damn fault. Now I am able to read the response...
Old 12-09-2006, 03:37 PM   #3
My Photos: (0)
Check out the code here http://www.sterntech.com/obdii_pic.php it has complete source code and schematics for a PIC based OBDII scanner.
Trampas
www.sterntech.com
Trampas is offline   Reply With Quote
Old 12-17-2006, 09:05 AM   #4
My Photos: (0)
What went wrong.
Can you explain what it was that you did wrong?
JuanaBee is offline   Reply With Quote
Old 12-21-2006, 04:51 PM   #5
My Photos: (0)
What "pic" are you referring too? i would like you're knowledge on the j1850 protocol if you have any. are you willing to share you're knowledge? is the pic you're programming something you bought, or something you actually programmed to logg and send data? if you programmed it with assembly etc,, we would defently need to share knowledge.
obdiiMasterMind is offline   Reply With Quote
Old 12-28-2006, 08:09 AM   #6
My Photos: (0)
PWM protocol
I have just finished writting up a document about the PWM protocol, send me an email if you want a copy. I will be adding it to my website here soon, www.sterntech.com.
Also on my website you will find firmware for a PIC 18F87xx which implements J1850.
Trampas
Old 07-11-2007, 06:07 AM   #7
My Photos: (0)
Hi
Could you please explain, how did you fix the problem.
I'm having the same problem with OKI MSM6636. After sending 0x61 0x6A 0xF1 0x01 0x00 the response is only 1 byte long, the value inside received register (at location 0x15) is 0x10.
Any direction will be helpful
manix is offline   Reply With Quote
Old 07-13-2007, 04:27 AM   #8
My Photos: (0)
Quote: Originally Posted by manix View Post
Hi
.. answer to myself
Problem fixed. There was a problem with interrupt handling time-gap. The host CPU periphery was set too slow; so OKI and SPI interaction also. The answer from the ECU was missed and the next IFR was read instead of the previous received answer.
Sponsored Links
vB code is On
Trackbacks are Off
2004 Ford F350 CarPC takissd Show off your project 23 08-31-2007 09:14 PM
FS Ford OEM stereo AUX input connector unit Davefocus Classified Archive 2 08-17-2006 02:49 AM
Question...Jaguar, Daimler, Ford... RoyN Off Topic 13 12-30-2005 04:25 PM
PWM j1850 response 0x10 Juan Wortley Engine Management, OBD-II, Engine Diagnostics, etc. 0 11-04-2005 02:56 PM
StevieG's Ford Focus Car PC stevieg Show off your project 78 08-19-2005 10:13 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
