The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 11-30-2006, 11:42 PM   #1
virengoyal's CarPC Specs
virengoyal's Avatar
Vehicle: Suzuki Swift 2005
My Photos: (0)
Need help to figure out OBD ii connections
Hi Folks,
Im new at this carputer concepts, but decided to try my hand at it. I have some questions regarding the OBD ii conections.
Here is an idea of my setup.
1. ITX mobo.
2. Centrafuse 4.1
3. Touch screen.
4. Drive a suzuki swift
Now i want to get the OBD readings from my car.
1. what hardware do i need to connect the onboard computer to my car pc?
2. Will centrafuse support the OBD ii reading or do i need to have another software running?
Please give me your valuable comments on this.
Thanks a ton and appreciate your help.
Regards
Viren
virengoyal is offline   Reply With Quote
Sponsored Links
Old 12-01-2006, 04:55 AM   #2
My Photos: (0)
What year is your swift and was it made for the US market?
Centrafuse will support all ELM327 compatible interfaces so it will be able to get the OBD readings provided you get a compatible interface, but the interfaces require an OBD II compatible vehicle (all 1996 and newer vehicles in the US will support OBD II)
I make an interface that works with centrafuse. Check out www.obdpros.com
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 12-01-2006, 01:54 PM   #3
virengoyal's Avatar
My Photos: (0)
Hi Mich,
Thanks for your reply, My car is a 2005 model swift. Do japenese cars follow the ELM327 standars?
Old 12-01-2006, 02:27 PM   #4
tolisn's Avatar
Vehicle: Mazda6
My Photos: (0)
Well, I have a Mazda6 JDM specs (CAN bus protocol) and the ELM327 works perfectly. Now if I could only find some open source VB OBDII software it would be great.
The road is long but we are getting there.
tolisn is offline   Reply With Quote
Old 12-01-2006, 05:00 PM   #5
My Photos: (0)
Quote: Originally Posted by virengoyal View Post
Hi Mich,
Typically Japanese cars sold in the US before 2006 generally use the ISO9141 protocol, this is supported by the OBDPros interface.
Paul
www.obdpros.com
Old 12-03-2006, 12:14 PM   #6
virengoyal's Avatar
My Photos: (0)
thanks once i figure out what connection and protocols my car runs on...ill will try and figure out my next step. Just recieved delivery of the MOBO...back to the test bench to get things running...Wish me luck
Sponsored Links
vB code is On
Trackbacks are Off
OBD II and Citroen Xsara ThePohorc Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-02-2008 08:41 AM
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
does this connector means i have obd II ? (Buick 95') tomer Engine Management, OBD-II, Engine Diagnostics, etc. 8 09-03-2007 07:03 AM
Where went the Guages in the OBD II plugin? bns2000 Centrafuse 3 08-11-2006 10:39 PM
Calculate HP base on OBD II data? god_of_cpu Engine Management, OBD-II, Engine Diagnostics, etc. 7 04-16-2004 01:43 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
