Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 12-03-2006, 02:24 AM   #1
PPE
PPE's Avatar
All New PCMSCAN v2.0!
Introducing the most powerful and advanced software available for your ELM interface! This new and improved version of PCMSCAN™ crushes the competition. PCMSCAN™ is an OBD-II diagnostic scantool that no vehicle owner should be without. In a class by itself, this state-of-the-art software comes fully loaded with new features. Here are just some of the things PCMSCAN™ can do for you:
-Find out the cause of your check engine light, look up trouble codes, and even turn off that annoying light and save a trip to the dealer.
-Test your car’s emissions readiness.
-Monitor and log data for a variety of parameters. View it with maps, gauges, tables, and graphs! Pause, fast forward and rewind your log files.
-Check out the new drag strip feature! The drag strip displays a countdown and timing light and measures your launch and reaction time. At the end of your run, you get a timeslip with the stats from the run.
-If you use aftermarket performance parts, the new digital dyno feature will let you test horsepower and torque to measure their impact on your vehicle's performance-- just try out the dyno and see if those parts were worth the money!
-Customize your own high-resolution dashboard with our new DashXL™ technology! If you own a CarPC, you’ll love the new DashXL™ system! This system features the most customizable dashboard editor on the market!
-For the power users out there, PCMSCAN™ now has built-in Javascripting support to do custom calculations on OBD-II parameters and data.
Stop by our website and download it today!
PCMSCAN - Check it out at: http://www.palmerperformance.com
PPE is offline   Reply With Quote
Old 12-03-2006, 02:28 AM   #2
PPE
PPE's Avatar
Here are some screenshots of some of the new features of PCMSCAN:
ProScan v2.0 - Professional OBD-II Scan Tool + Dyno ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 48 01-15-2008 05:44 PM
PCMSCAN integrated into RR sandworm Engine Management, OBD-II, Engine Diagnostics, etc. 17 01-20-2007 02:28 PM
PCMSCAN + Subaru, which adapter benetton Engine Management, OBD-II, Engine Diagnostics, etc. 22 11-28-2006 01:32 AM
PCMSCAN embedded? bigjoe22 RR Skins 3 04-18-2006 03:57 PM
mazda 6 carputer v2.0 skeurton Show off your project 9 06-23-2004 04:37 PM
