The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 12-11-2006, 10:36 AM   #1
My Photos: (0)
ASCII stupid question, get a stupid ANSI
In OBD2, does the vehicle and the interface talk to each other in binary or ascii ?
I was just wondering since it seems like the interface and PC usually talk to each other in ASCII. A typical command/request sent to the interface and the response back from are like those shown in the attached pic.
As you can see the command "0111" is actually 4 ascii bytes, instead of two binary bytes and the response is 11 ascii bytes which could possibly be sent as 3 or 4 byte binary. But thats PC<->Interface. What happens between Vehicle<->Interface ?
It's A Honda is offline   Reply With Quote
Sponsored Links
Old 12-11-2006, 10:50 AM   #2
PPE
PPE's Avatar
My Photos: (0)
The OBD-II communication between the vehicle and the OBD-II interface is always binary communication. The ELM interface is the only one that I have seen so far that uses an ASCII protocol to talk to the PC. It just basically converts the ASCII to binary before sending the message on the OBD-II bus. And when it receives an OBD-II message, it converts it to ASCII and sends it up to the PC.
-Brian
www.palmerperformance.com
PCMSCAN - Check it out at: http://www.palmerperformance.com
PPE is offline   Reply With Quote
Old 12-11-2006, 03:22 PM   #3
My Photos: (0)
Thanks Brian. Strange why elm would do such a thing ? Seems like a waste of valuable processing time and bandwidth - especially when running at barely 4Mhz!
Old 12-11-2006, 03:34 PM   #4
My Photos: (0)
Odds are had they not done it, they would not have been one of the more popular chips out there. It made it possible to use the interface without any retail software at all (through windows hyperterminal) and it also made it pretty easy to understand when new developers wanted to start writing apps against it. It makes far less sense that they built the ELM327 this way, but you want your product to be backwards compatible as well.
Joel Konecny
Digimoto OBDII Diagnostics
digimotojoel is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Stupid Dos question Dustin Haug Software & Software Development 7 06-07-2001 07:01 AM
Is this a stupid question?? Raymond Power Supplies 1 05-23-2001 12:01 PM
a stupid question... rep999 General Hardware Discussion 6 04-01-2001 01:19 PM
Stupid question...?again... Meoff General Hardware Discussion 1 06-22-2000 07:09 PM
Can I ask a stupid question? adjolley General Hardware Discussion 4 11-24-1999 02:58 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
