ELMscan Ford AU falcon (OZ)
Have been searching forums for ways to make this unit work with my AU2 XR8 falcon
it has an OBD2 type connector - but I am unsure if it uses the std odb2 protocols
With an NGS star diagnostic unit - I can get all the pids and also retirieve real time information - but borrowing it from work is a nightmare
Does anyone know whether the elmscan5 will pull information all the information from the car.
I can connect to it - using pcmscan but onlly 8 of 98 pids are identified
If there is a config file to make this work - I am interested in knowing the details.
I am trying to diagnose a problem with the car - prior to doing an edit to the ECU
ANy information or help would be appreciated.
BTW - the scantool v1.13 software does not recognise connection with the ecu - PCMscan seems to give some information - still trying other softwares - but i have the feeling it could be an obd1 with a odb2 interface on the car???? - stumped
Will try the hyperterminal and see if I can get some detials re-connectivity of the elmscan device
What do others use to get the pids?
Thanks in advance
O
