Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 12-27-2006, 08:48 AM   #1
Mode $06 question
I understand that mode 6 is for 'non-continous test results' that the pcm stores after it has completed testing of involved components, but recently I found this that I am not quite sure what to make of it -
http://www.aa1car.com/library/honda_mode06.pdf
Its a list of test ids for mode $06 for honda. So when they say that for a 4cyl accord the test id for EGR flow is $03 and comp id is $81, how is that useful to someone who wants to query the egr flow ? How exactly do I interpret this table ? What command should I send to the interface ?
I am using OBDPro, it that matters.
It's A Honda is offline   Reply With Quote
Old 12-27-2006, 10:42 AM   #2
Maybe this will help you get started: http://www.mp3car.com/vbulletin/engine-management-obd-ii-engine-diagnostics-etc/75252-mode-06-revealed-why-such-secret.html
Joel Konecny
Digimoto OBDII Diagnostics
digimotojoel is offline   Reply With Quote
Old 12-27-2006, 03:46 PM   #3
thanks. that should definitely help me get started.
I wonder why ignition timing is included in mode $01 as a generic real time sensor available to obd2, yet knock sensor is not available even in mode $06 components, since knock sensing influences timing and thereby emissions directly.
Problem with portrait mode (600x800) on Lilliput 8.4 Touch screen display. rac3pm LCD/Display 3 11-05-2006 06:42 PM
feature request: mix mode liquid_smoke Road Runner 4 10-22-2006 07:50 PM
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 05:15 PM
Sirf Advance Gps Mode Help mick0uziel Map Monkey 26 03-22-2006 03:19 AM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 09:03 AM
