The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 12-30-2006, 04:25 PM   #1
Rik
Rik's Avatar
Vehicle: Volvo V40/2002
My Photos: (0)
Volvo V40 2002
Hi all,
I got my elmscan 5 usb today and connected it to my car (Volvo V40 from 2002). But no matter what software I use, It won't work. And the Volvo V40 is listed in the compatibility list. The scantool software tells me that it cannot recognise the protocol or something like that. Does that ring a bell for someone? Hope it does....
Thanks.
Rik
Rik is offline   Reply With Quote
Sponsored Links
Old 12-31-2006, 04:41 PM   #2
v1per's CarPC Specs
v1per's Avatar
Vehicle: 2000 Nissan Maxima GLE
My Photos: (0)
I see you are in the Netherlands. This is most likely the problem. I do not know what the emissions laws there are but to understand this you need an OBD history lesson.
The OBD-II system was mandated by the EPA for emissions testing. It gives inspectors a standard interface with which to check emissions compliance. All features beyond these were simply put in place by individual car manufacturers in order to simplify problem diagnosis. The Netherlands either does not require OBD-II at all or only required it after your car was manufactured (the EPA made it madatory in 1996 but in Australia, for example, it has only been required since 2006 (I think it's 2006, but if not, you still get the idea)).
So if the Netherlands does not require OBD-II your car most likely doesn't have it. So, even after vehicle diagnostics have been standardized, they still aren't standard (if that makes any sense).
v1per is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
What's with the sudden flood of newbs? ShinkunoNamida Off Topic 17 03-29-2007 01:43 PM
VW Golf TDi MK4 2002 ODB cable confusion - which one is the right cable? f1lby Engine Management, OBD-II, Engine Diagnostics, etc. 3 02-19-2007 07:19 AM
** Volvo C70 SC-805 Head Unit & AUX In ** billyb0b General Hardware Discussion 5 02-13-2007 12:04 AM
Volvo S60 in-dash project JC-S60 Fabrication 41 09-10-2005 09:43 PM
Project-Start on VOLVO S80 D5 2002 Diesel-Junkie Newbie 5 08-18-2005 05:35 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
