The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 01-02-2007, 08:08 PM   #1
NekkidRidr's CarPC Specs
My Photos: (0)
OBD-II devices in Centrafuse..Serial or USB?
I'm using the current beta of the new Centrafuse XLE, and I'm getting ready to add OBDII info to the setup. Does is matter if the device hooks up via serial or usb? I've seen mostly serial interface devices but I am starting to see more and more USB interface ones. Does anyone know if Centrafuse cares how it's hooked up?
NekkidRidr is offline   Reply With Quote
Sponsored Links
Old 01-02-2007, 08:17 PM   #2
My Photos: (0)
I know nothing about Centrafuse, but both USB and Serial devices use COM ports, it should not matter to the software which one uses which. There are virtually no benefits to using a USB device if you have a serial port on your computer, it is more a convenience for people who do not (which is becoming more and more common).
Joel Konecny
Digimoto OBDII Diagnostics
digimotojoel is offline   Reply With Quote
Old 01-02-2007, 08:19 PM   #3
My Photos: (0)
Perfect
Thanks so much!
Old 01-02-2007, 08:51 PM   #4
My Photos: (0)
Just to add to that, some of the app's only support COM ports in the single digit so com10 etc might nor work, I do not have a vlaid license for centrafuse anymore so cannot validate this, but you should double check to make sure that centrafuse does not have such a limitation
michbound is offline   Reply With Quote
Old 01-02-2007, 08:54 PM   #5
My Photos: (0)
Thanks!
Sponsored Links
vB code is On
Trackbacks are Off
Powered Hub, Lots of USB Devices! Will this work? adamharrisuk General Hardware Discussion 4 05-14-2006 11:00 PM
Confused About OBd II USB husalah5150 Newbie 2 03-29-2006 09:44 AM
OBD USB or LPT1 Connectors? Ritalin Kid General Hardware Discussion 11 09-19-2003 10:01 PM
USB to serial Sleeka General Hardware Discussion 2 12-24-2002 03:55 PM
hmm anyone up for building their own usb 2 serial oddcomp General Hardware Discussion 2 10-21-2002 01:11 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
