Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 01-16-2007, 05:51 PM   #1
neon2L16v is an unknown quantity at this point
obd-II on a chrysler neon
hi all any one know if a chrysler neon year 2000 model in the uk is odbii complient or not iam not sure as all the websites with deatils on odbii only list the dodge neon models. thanks for your help
neon2L16v is offline   Reply With Quote
Old 01-16-2007, 05:55 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
if it's post 1996 it should be OBD-II complient...at least in the states that's the way it is.
Can you see the port under the dash?
It should be a two row port. A pic of it will help us determine.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 01-16-2007, 06:31 PM   #3
VENDOR - OBDPros
michbound is on a distinguished road
, also check this link
http://www.auterraweb.com/obdiipinout.html
That should tell you based on the pin's what protocol you might have, most likely if you have the connector then the neon should support ISO-9141.
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Need help to figure out OBD ii connections virengoyal Engine Management, OBD-II, Engine Diagnostics, etc. 6 02-19-2009 06:03 AM
OBD II and Citroen Xsara ThePohorc Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-02-2008 09:41 AM
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 02:06 AM
does this connector means i have obd II ? (Buick 95') tomer Engine Management, OBD-II, Engine Diagnostics, etc. 8 09-03-2007 08:03 AM
Where went the Guages in the OBD II plugin? bns2000 Centrafuse 3 08-11-2006 11:39 PM
