Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 03-14-2007, 12:19 PM   #1
Using OBDII connector for Charging Source
Hi All,
New to the forum and I would like to start out with a wierd request for comments, first a bit of background.
I have a customer who wants our company to develope a rechargeable flashlight that would plug into the OBD connector for power to recharge the light. This would be very small and would require very little current but would reside in the connector until needed. I assume that this would be marketed as a giveaway or promo item.
Besides a few of the obvious issues (being in the way of your legs, connector located behind a panel or in ashtray compartment) can anyone think of some valid issues that I can use to discourage this waste of time? Or is this something anyone thinks is a good idea?
Thanks in advance
unitic_mrm is offline   Reply With Quote
Old 03-16-2007, 11:04 AM   #2
most/all cars will have a cigarette sockets which cost little money to replace if broken with relative ease, the same cannot be said for OBD2.
This is a stupid idea.
Lowtechguy is offline   Reply With Quote
Old 03-16-2007, 12:08 PM   #3
i'd go with the cig lighter idea too. I'm sure you could make (if it doesnt already exist) a torch the exact size of the actual cig lighter.
DavC is offline   Reply With Quote
Old 03-16-2007, 03:26 PM   #4
Cig lighter might be an alternative except I think the idea is to leave the cig port available for other accessories like a Cell charger etc so from that view point this might not be an extremely stupid idea.
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 03-28-2007, 07:38 AM   #5
The6's Avatar
Paul
OBDPros
So why not just add another cig lighter port somewhere.
The6 is offline   Reply With Quote
Old 03-28-2007, 10:45 AM   #6
in that case add a daisy chain type input on your device so you can run another device through.
obd 2 ports are sometimes in odd places so its not as practical either.
Old 03-30-2007, 05:55 AM   #7
The6 & Lowtechguy,
You guy's have a point , I was just trying to guess at the OP's motivations.
Paul
OBDPros
Open Source OBDII scanner Trampas Engine Management, OBD-II, Engine Diagnostics, etc. 0 12-09-2006 03:35 PM
Open source OBDII Trampas Engine Management, OBD-II, Engine Diagnostics, etc. 2 11-16-2006 10:00 AM
Read OBDII Source Code? Zharvek Engine Management, OBD-II, Engine Diagnostics, etc. 6 05-19-2005 07:31 PM
GPS:MM shutdown RR when switch skin MatrixPC RR Bug Tracker 5 05-12-2005 11:07 AM
master volume doesnīt work free2world8000 RR Bug Tracker 14 02-17-2005 12:08 PM
