The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Search this Thread Display Modes
Old 03-18-2007, 02:17 PM   #1
My Photos: (0)
OBD II to USB...
i am looking for a OBD II to usb adapter so i can hook it up to my carputer...
any recommendations ?
i didn't find a nice list in the forum and i was hoping for some help...
thx
phil
sgtpepperaut is offline   Reply With Quote
Sponsored Links
Old 03-18-2007, 02:55 PM   #2
My Photos: (0)
Checkout my USB reader www.obdpros.com, works with all the ELM software and supports USB 2.0
Also cheaper than any USB based multiprotocol scantool out there
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 03-28-2007, 10:27 PM   #3
Vehicle: 2003 Ford BA Falcon XR8
My Photos: (0)
Does the USB tool work at the same 128kpbs speed as your serial too?
I'm interested in a Scantool that can run at the full HS-CAN speed of my car (2002 Australian BA Falcon XR8 with CAN 11bit 500kbps - I'll post a full topic on it shortly) and it occured to me that even USB 1.1 can run above that. However, I suspect the limit would be with the actual chip used to do the OBD2/Serial conversion and not with the USB side of it. My assumption at the moment is that you're embedding a USB Serial chip in your Scantool and it will appear as a Serial port to the Host PC.
Would any of my assumptions be close to the mark?
Luke Plaizier
Lukeyson is offline   Reply With Quote
Old 03-28-2007, 10:45 PM   #4
My Photos: (0)
Luke Plaizier
Hi Luke,
Yes that is correct, the USB version uses an USB to Serial chip so it looks like a com port to the PC. The other ELM327's peg the speed at 38K so in that regards the OBDPro supports faster speeds, but on a 500 KBit bus you would still need to filter for a range of CAN Id's to avoid packet loss.
Paul
OBDPros
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 11:49 AM
Pocket-Pc OBD II ? paul1 Engine Management, OBD-II, Engine Diagnostics, etc. 9 12-13-2006 05:57 PM
OBD II software for bmw kostsour Engine Management, OBD-II, Engine Diagnostics, etc. 5 11-05-2006 12:50 PM
Where went the Guages in the OBD II plugin? bns2000 Centrafuse 3 08-11-2006 10:39 PM
Confused About OBd II USB husalah5150 Newbie 2 03-29-2006 09:44 AM
Sponsored Links
Ad Management by RedTyger
