The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 03-26-2007, 06:17 PM   #1
My Photos: (0)
OBD II (OBD-DIAG freeware and OBDpro hardware)
Hi,
I was wondering if anyone has used the OBDPro with this fantastic freeware (OBD-DIAG). I tired using the OBDPro with the free software that came with it and it worked fine, however I wanted to have the OBD-DIAG and after reading all the reviews on the forum, I was lead to believe that it works well with ELM327 compartable hardware which is what i have. I however keep on getting the error message " can't find the AVG diagnostic"
Please help anyone with any good ideas
Patrick
Patrick123 is offline   Reply With Quote
Sponsored Links
Old 03-27-2007, 03:49 AM   #2
My Photos: (0)
Hi Patrick,
Since you mention that the other software works fine, we should be able to get the OBD Diag to work also.
Couple of questions to help diagnose the issue
1. Connect to the OBDPro via hyperterminal and set the protocol to Auto by typing in ATSP0. Then type in ATZ to reset the interface and then type in ATDP. The interface should respond with AUTO.
2. At this point shutdown hyperterminal and start OBDDiag and see if this fixes the issue you are having.
What vehicle are you running this on?
Let me know if you still have problems and I will dig into this some more.
Paul
OBDPros
michbound is offline   Reply With Quote
Old 03-27-2007, 07:04 PM   #3
My Photos: (0)
Hi Paul,
Thanks so much. The OBDPro hardware now works perfectly with the OBD-DIAG free software.
Thanks again
Patrick
Old 03-29-2007, 10:10 PM   #4
grayvader's CarPC Specs
grayvader's Avatar
Vehicle: 2005 Ford F150 SuperCrew FX4
My Photos: (0)
Paul,
I'm having the same problem, but when i use a terminal program and follow your instructions, it doesn't fix it. I did get the AUTO response from the OBDPro, but OBD-Diag still gives the AVG Not connect error.
any other suggestions?
(2005 Ford F150)
thanks,
gray
p.s. other programs (streetdeck, scantool) work fine
grayvader is offline   Reply With Quote
Old 03-30-2007, 12:41 AM   #5
My Photos: (0)
The OBD-Diag hardware does communicate a little differently (so I would imagine their software does too). We have some of their hardware in house we have been looking at to integrate with Digimoto and we noticed a few variances we need to account for. I would contact Folker on the mp3car forum here (he has an account) and talk to him directly regarding his software. It would be easier for him to describe the problem then for Paul.
Joel Konecny
Digimoto OBDII Diagnostics
digimotojoel is offline   Reply With Quote
Old 03-30-2007, 05:53 AM   #6
My Photos: (0)
Quote: Originally Posted by grayvader View Post
Paul,
(2005 Ford F150)
thanks,
gray
Hi Gray,
Did you install the OBDDiag off the CD? Patrick was able to fix the issue by reinstalling the OBDDiag from the CD. Give that a try and if you still have problems PM me a contact # and I can call you to work through the issue.
Paul
Old 03-30-2007, 10:44 AM   #7
My Photos: (0)
My bad, I must have skipped a response there, it doesn't look like there is a compatibility issue at all.
Joel Konecny
Old 03-30-2007, 10:20 PM   #8
grayvader's Avatar
My Photos: (0)
Ah! Thanks man. The one on the disc worked great. Silly me, i got the latest one off their site the first time.
Old 03-31-2007, 07:14 AM   #9
My Photos: (0)
I will look into what's going on with the version on their website today.
Paul
OBDPros
Old 04-12-2007, 08:41 PM   #10
My Photos: (0)
I've had the same experience, OBD-DIAG does not see my ELM-327 (home built interface based on their schematic - working with most other software).
I've tried the solution above and get back the AUTO response as well, but OBD-DIAG still does not see the interface. I downloaded the software from their website this past weekend, vers 1.01.00. Is this other CD version mentioned above available online somewhere? what is the version number??
Is there any way to manually specify the interface type in this software?
thx
jmanng is offline   Reply With Quote
Sponsored Links
Old 04-13-2007, 06:22 AM   #11
My Photos: (0)
thx
Hi jmanng,
I think the newer version of the sotware most likely has a bug since there is no reason for it not to recognize an ELM327 when other software recognizes it.
Did you try contacting the developer? I will find out what version # we ship on the CD and get back to you on that one.
Paul
www.obdpros.com
Old 04-13-2007, 08:59 AM   #12
My Photos: (0)
Hi Paul:
I have taken your advice and forwarded off an email to their support.
Thanks for researching the version number that people are having success with.
Jaime
Old 04-17-2007, 09:19 PM   #13
My Photos: (0)
I also downloaded the 1.00.02 version on their site and tried and had no better luck with it (tried the same trick above with using hyperterminal to first set elm 327 v1.1 into auto mode)...
Email forwarded to the support address listed in product bounced back as undeliverable... guess it's hard to keep up with the inquiry of the minions.
Hi Paul (or anyone), any luck tracking down that version # that worked, I would be most appreciative knowing the version and trying to get a copy to test out.
Thanks,
Old 04-18-2007, 02:51 AM   #14
My Photos: (0)
The version that I tested with is v1.01.00. PM me your email and I can send you a zip of that version
Paul
www.obdpros.com
Old 03-30-2008, 11:52 PM   #15
My Photos: (6)
help me please
hi , i have a ELM327 interface , this
Highslide JS
but no working with the OBD-DIAG software , i test with other software and working perfect , but i want used with that software OBD-DIAG , any one have any configuration or somethink what i can used my interface ? thanks mikee
mikeeps2 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
