Go Back   MP3Car.com > Mp3Car Technical > Environmental Considerations in Mobile Computing
Old 07-03-2009, 05:44 PM   #16
Maheriano will become famous soon enoughMaheriano will become famous soon enough
Quote: Originally Posted by joshuo View Post
Has anyone had their touchscreen fail from heat?
My friend has a Xenarc 700tsv here in Florida on top of his dashboard in an untinted car, and one day the touch was gone from his screen .
It kinda scares me since i have the same screen, however I Will have it built into the console where the radio is (was).
I ran the same screen in Atlanta through August - December with no issues. It was too hot to touch it with my finger but it still works.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 07-03-2009, 05:53 PM   #17
joshuo is an unknown quantity at this point
thanks, that gives some assurance. his died over just a few months...
joshuo is offline   Reply With Quote
Old 07-03-2009, 07:14 PM   #18
tempgp's Avatar
tempgp is an unknown quantity at this point
some touch screens just die by themselves.
i run TM-868 and RMA rate on those is 30%
TM-868 V1 had 90% RMA rate, gee thats like 1 of 100 units had few chances ow working
Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
Bluetooth Cell Phone CallerID [Pre-Alpha]
Custom Button Bash Board - Add physical touchable buttons to your CarPC Project
Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
tempgp is offline   Reply With Quote
Old 07-04-2009, 04:52 PM   #19
kirk78h's Avatar
kirk78h is an unknown quantity at this point
This is actually the biggest problem I've had with my CarPC. I also have the Carnetic 2140 which seems pretty sensitive to heat.
I would mount everything in the trunk; except I have a hatchback. Before summer, I had my windows tinted to the max legal limit in Maryland. This helped some; but did not solve the problem. This past week, we had outdoor temperatures of 80 - 82F, and my system would not turn on until I ran the AC for 8 - 10 minutes. So far, this has been a very mild summer. Also, the little fan mounted in the 2140 is incredibly loud. I've thought about replacing it with something more efficient and quite.
I'm very interested in this thread, and will watch for anyone to post alternatives to help this.
Kirk
kirk78h is offline   Reply With Quote
Old 07-04-2009, 06:31 PM   #20
hommersimpson is an unknown quantity at this point
Well if anyone has looked at my build.. Im interested in this to... as my pc is mounted directly under the dash.. I plan on running duct work from outside car to bring in fresh air.And plan on haveing a/c ducted to it also..But i sure as hell dont wana loose touch screens...
http://www.mp3car.com/vbulletin/work...ash-build.html
hommersimpson is offline   Reply With Quote
Old 07-18-2009, 08:44 AM   #21
Fox_Mulder's Avatar
Fox_Mulder is on a distinguished road
Xenarc 700TSV + Old School Lilliput 7" TS survived the heat here in Australia when it was about 45 * C outside
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
Fox_Mulder is offline   Reply With Quote
Old 07-18-2009, 11:26 AM   #22
tempgp's Avatar
kirk78h, if your comp dies at 80F (26C) maybe there something wrong with the components... 26C is regular temp for comps. I actually have 26C in my room rightnow. So check components and see what exactly causing the failure. You siuld not see problems at least untill temp heat 32-40C
Old 08-04-2009, 03:23 PM   #23
archaic0's Avatar
archaic0 is an unknown quantity at this point
My touch screen is pretty much in direct sunlight at times in parking lots and while the screen hasn't failed, the case of the screen has warped a little. It hasn't effected operation as of yet, but it makes me want to get some kind of silver reflective cover for it maybe when I know it'll be in the sun for a while parked.
As for cooling options, the peltier idea has been mentioned over and over through the years and I think I'm about to attempt a peltier solution. Most people go directly to one of two things when it comes to peltiers: condensation or the excess heat from the hot side of the thing. I think it can be managed though if the point is to simply make sure something like a trunk is in an operating range. The purpose isn't to get the computer or the environment down to 'cold' temperatures, but simply to bring the environment down under that 100F / 38C threshold that seems to be a breaking point sometimes.
My idea would be to install a peltier under the spare tire with the hot side of the device exposed to the outside air. Then have a fan blowing across the cold side into the trunk.
The air coming off the peltier may be super cold, but by the time it mixes with the trunk air when it's over 100F/38C I can't see the trunk getting much cooler than 80F/27C.
With that kind of a setup you would have a small footprint for the cooler, it would be out of the way, and I can't see any condensation issues since there's no way a small peltier could get an entire trunk down to a dew point. But it should be able to get the environment just that little bit cooler that the components like.
Comments?
archaic0 is offline   Reply With Quote
Old 08-05-2009, 06:07 PM   #24
thejavabuddha's Avatar
thejavabuddha is an unknown quantity at this point
You will HAVE to post details on how this works out!
thejavabuddha is offline   Reply With Quote
Old 08-06-2009, 03:34 PM   #25
archaic0's Avatar
I've been shopping for a peltier to use and I think I'm going to gut a portable 12v cooler to make my solution. They advertise being able to drop that small space down 40 degrees under ambient (so down to 70 degrees from 100). I think that should be perfectly sufficient for a car trunk. I'm thinking that I'll make a square duct from the bottom center of the tire well where the peltier will live to the back of the trunk (towards the rear of the car) for input air. Then I'll have a fan vertical in front of the peltier blowing across it to a square duct that exits towards the front of the car.
I wonder if I should mount a heatsink to the cold side to blow through? That makes sense right? (anyone who's worked with peltiers know the answer to that?) If it works for heat it'll work for cold too since it's the same principle I think.
Old 08-06-2009, 04:06 PM   #26
archaic0's Avatar
I did a quick mockup just in case anyone didn't follow what I meant. Obviously the scale is way off, but this is the idea.
The target temperature for the trunk would be 80F / 27C when it's 100F / 38C outside.
http://www.dvigroup.net/share/pictur..._diagram_1.jpg
This also has the side benefit of cooling my car stereo amp. I don't thermal it very often, but on very hot days while I'm on a road trip and thumping pretty hard down the highway it's been known to happen. I usually just drop the back seat down to help my air get to it from the front in those cases.
Old 08-08-2009, 07:11 AM   #27
hexxamillion's Avatar
hexxamillion is on a distinguished road
I'm interested to see what the final solution you use for ambient cooling. I have been brainstorming a solution for this for a while for use with in-car solar power.
See my post regarding using solar energy in the car. I am still brainstorming this and my second main issue how to relieve some of the heat in my car while it is idle. I live in climates that can reach up to 120F in the summer. Imagine how hot that it ends up being inside the car. http://www.mp3car.com/vbulletin/how-...ur-laptop.html
So yes, I am curious to see what your cooling solution will end up being.
....I just wanted to add on other thing..it's funny someone in this post mentioned the idea of gutting a 12v portable cooler...LOL! I was investigating that idea also.
"Live Free!!!...It's all about Open Source"
Worklog: '05 Nissan Altima Project (Intel D945GCLF2D)
Project #2:Solar Power Integration
Vimeo Vids:Project Videos
Blog: Hexxamillion.com- 100% Powered by Wind Energy
Twitter:http://twitter.com/hexxamillion
hexxamillion is offline   Reply With Quote
Old 08-09-2009, 10:36 AM   #28
My question is how much power (electricity) does it take to drop the temp by 30 degrees? Would it overload the battery between an amp, pc, and a cooler for the trunk? I'm sure the little fan wouldn't take up all that much, but I know heating stuff takes a lot of juice so I imagine doing the opposite would require a fair amount too.
Old 08-09-2009, 11:06 AM   #29
Injector's Avatar
Injector is on a distinguished road
why don't you go in the offensive instead of the defensive and tint your windows, my car dropped 10 -15 degrees since i got my windows tinted.
PS: don't cheap out on the film buy the good stuff, it'll work better and it won't fade or peel off, i got Formula1
Injector is offline   Reply With Quote
Old 08-10-2009, 01:34 PM   #30
archaic0's Avatar
My windows are tinted now, and the environment outside ranges from 90-110 outside usually but can climb a little higher. My stuff is in the trunk, out of the sun completely so the tint didn't change the trunk temp of 90-100 after being in a parking lot for several hours.
No matter how dark it is in the trunk, it's still a metal box sitting in the sun. So eventually it will at least match the ambiant air outside. With insulation you might be able to keep it 5-10 degrees lower, but that may not be enough.
People reference the trunk being MUCH cooler than the car, and that's usually true since on a 100 degree day the inside of the car can get to 140 or 150 easy with the right conditions. The trunk will still be close to 100 though and that's too hot for a lot of the components to be running at.
My biggest problem right now is actually my startup/shutdown controller. The PC itself has never had a glitch even up to 120 degrees. The cpu and hard drive are kicking just fine, but that startup/shutdown controller starts fritzing out at 100 or so. It may not be GOOD for the PC to run that hot, but it will run none the less. The startup/shutdown controller isn't as tollerant.
Which is how *I* got to this peltier idea. The cooling should allow the startup/shutdown controller to function, and as a bonus the PC will be much happier.
I'm sure the current draw for the peltier is pretty high, but part of MY plan anyway is to put in a second battery with an isolator (seperate from the heat issue, I have a voltage drop issue now since the PC is right off the car power since I'm using a simple startup/shutdown controller instead of a DC power supply). The peltier would be powered off the second battery along with the PC while my stereo amp would remain on the normal power.
If the second battery dies, that's fine. But I bet I could come up with something that delays the starting of the peltier until I unlock my doors. And that same delay component might delay the startup/shutdown controller as well. Just to give the peltier a minute or two to start pushing some cool air around.
Touchscreen Issues w/Hibernation & CNX-P1290 jmciver Power Supplies 0 12-20-2006 08:48 PM
Verizon Novatel 620 issues MobiTekLink Wireless Communications 30 12-02-2005 04:35 PM
To heat sink or not to heat sink ... jnusaira Newbie 5 02-18-2004 10:46 AM
CPU Heat question: Which one would generate less heat? kiztope General Hardware Discussion 6 02-12-2004 03:14 AM
COOLING THE CARPUTER moahdib General Hardware Discussion 33 07-04-2002 09:18 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
