Go Back   MP3Car.com > Mp3Car Technical > Environmental Considerations in Mobile Computing
Old 08-25-2009, 12:33 PM   #1
Punky is on a distinguished road
Extreme Temp Hard Drive Experiences
With all the discussions going around about operating hard drive at extreme temps, I think its a good idea to have a thread devoted to user's experience with their HD. So other users can make informed decisions when they purchase hard drives for their carpc.
Please post your hard drive model and working limits, also where your pc is mounted.
Here is mine:
Patriot Warp V.2 mounted in the trunk
Max Temp: +33*C
Min Temp: -15*C (broke after)
Wouldn't recommend this one for cold winters.
OCZ Vertex 32GB mounted in the trunk
Max Temp: +33*C (this is as hot as it gets here this summer)
Min Temp: Will report once winter hits
Punky is offline   Reply With Quote
Old 09-17-2009, 10:37 PM   #2
eigenVector's Avatar
eigenVector is an unknown quantity at this point
Punky, what tools are you using to read the OCZ Vertex temps? I can't get HDTune to get a read on mine.
Anyways, here's my past experience:
Climate: Sprint/Summer North Carolina
Hottest Day: 90F
WD Scorpio Black 320GB 7200RPM mounted in the trunk
Max Temp: +59C
Min Temp: Did not use in winter
I replaced this drive because I did not wish to let it exceed Western Digitals max operational temperature for this drive of 60C. Anything above 50C would show a dramatic drop in performance on my PC as well. I replaced it with the same OCZ Vertex 32GB as Punky, but do not know the operational temperatures. I moved the WD to my laptop as a data drive, and it is operating as good as new. The OCZ is super fast. Quick boot times, fast image texture loading on my mapping software too.
eigenVector is offline   Reply With Quote
Old 09-17-2009, 11:24 PM   #3
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Every 6 months or so this topic gets trotted out.... Even the same model from the same mfg can have different results.
I do not think you will get a be all end all answer even if everyone that is currently reading and posting answers.
That being said.... I run the cheapest drive I can with out issue in record low and high temps in Denver.
The rest of the specs are in the sig.... nothing special and not one issue, mounted in the center console.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 09-17-2009, 11:53 PM   #4
Hottest Day: 90F
Max Temp: +59C
My old case had a temp probe which i placed on the HD to read the temp.
I did noticed that the OCZ is extremely fast as well, perhaps too fast for a carpc, but hell its pretty cheap so who cares!
I doubt exact same HD will perform exact the same under the same condition, but
they would be very similar, and hence why i created this thread.
I too ran a lot of 3.5" in 35*C to -45*C, and they performed fine, but i see a huge performance drop in sub 30*C temps, even times where there's huge delay for the drive to spin up before boot.
Old 09-18-2009, 10:53 AM   #5
nobb will become famous soon enoughnobb will become famous soon enough
Good idea to have this thread. I wish there would have been better user data as to which drives would work in the winter, then maybe I wouldnt have gone through so much money blindly picking out drives when I first got started with my carpc. All of my "normal" 3.5inch desktop non extreme environment drives have died or started to go bad after being exposed to the cold. Calgary's winters hit hard, so its pointless to run a normal hard drive here.
>Hitachi Endurastar 4200rpm. Sold to punky after, forgot if it was the 20G or 30G model. tested down to -30C, never had a single problem.
>Seagate EE25 20G, rugged model. Rated by Seagate to work down to -20C, but from my testing it's only good down to -27C. Below that, you have to wait until the drive warms up a bit. I suspect the liquid bearings are too viscous. After having a few extra seconds to spin up, the drive is good.
>Seagate EE25 80G, extreme model. Rated by Seagate to work down to -30C. From my experience, even at -35C it was good. No experience with temperatures below that. This is my top choice for a hard drive so far.
>OCZ Summit 60G. Just got this and replaced my EE25 as the main drive, will update when winter hits.
nobb is offline   Reply With Quote
Hard Drive to Handle Extreme Cold? phuz General Hardware Discussion 7 12-23-2007 06:32 PM
My hard drive situation PhatHam Newbie 3 10-26-2006 01:50 PM
Hard drive shock / vibration thoughts S11D336B General Hardware Discussion 60 09-27-2006 12:40 AM
MB870 & Slimline Floppy Drives McGreggor General Hardware Discussion 5 11-09-2005 07:32 AM
Help!!! laptop hard drive ashbosh General Hardware Discussion 9 07-15-2005 02:34 PM
