Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 04-19-2007, 02:10 PM   #1
Jakiii's Avatar
Jakiii is an unknown quantity at this point
2004 Honda Civic Si Screen Bezel - CAD Part
I just finished this bezel for my Civic. I created 3D data in Alias StudioTools, then output an SLA part. I made a mold of that SLA part and cast the final piece in resin, then painted. Here are photos of the finished piece as well as screenshots of the data.
Jakiii is offline   Reply With Quote
Old 04-19-2007, 02:48 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Very nice.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 04-19-2007, 03:38 PM   #3
guizai is on a distinguished road
wow. professional. Could you describe your fabrication process a bit more? What is an SLA? These are all tools you have yourself or did you get an outside company to do it? Any details you can provide would be appreciated. I would love to find a place that could design and fabricate a bezel for me. Mine is currently cut out of ABS and looks like ***,
guizai is offline   Reply With Quote
Old 04-19-2007, 03:51 PM   #4
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
wow, that's some technique you have there, sure beats the bondo & sanding deal
I'd think that'd be way to much to do for only one piece, but man, I wish I had that kind of stuff available.... more info on it would be great! looks 110% perfect..., I'm guessing modeling stuff like this is your profession?
turbocad6 is offline   Reply With Quote
Old 04-19-2007, 04:11 PM   #5
GoHybrid's Avatar
GoHybrid is on a distinguished road
rapid prototyping cost $5/in^3 when i was in school.... that's why i didn't do much of it.... but i'll be damned if that's not the way to make patterns. Good work man!
GoHybrid is offline   Reply With Quote
Old 04-19-2007, 04:58 PM   #6
Jakiii's Avatar
I'm an industrial designer so I have some practice making parts. Rapid prototyping is basically 3D output of a computer model, like an inkjet printer that works in the third dimension. It's not cheap to make something this way, especially if you're only making one of them, but I have resources at work I can call upon. The skill is knowing how to model parts in the computer, but there is a fair amount of old world technique behind that paint, Bondo, sanding, etc.
Old 04-19-2007, 05:11 PM   #7
N6BER is an unknown quantity at this point
Looks very very nice but that's not a US version of the 2004 Civic SI is it. I have a 2004 Civic GX and the center console is a quite different.
N6BER is offline   Reply With Quote
Old 04-19-2007, 05:28 PM   #8
Jakiii's Avatar
GUIZAI,
SLA is an acronym for stereo Stereolithography. Wiki it and you'll get a better description than I can offer. The process is this:
1) Get your hands on the factory mass-production data (computer model) of the center panel in your vehicle.
2) Spend a few years becoming proficient in a CAD surfacing software such as Catia, Alias, 3D StudioMax, Rhino, etc.
3) Model your bezel in the computer. Give yourself a .5mm gap between your part and the center panel, make nice highlights, nice fillets, and create backside to you part that matches the screen you're using. In my case I measured screw bosses and stoppers from the Lilliput housing my screen came out of.
4) Output your model in 3D using SLA or FDM or CNC process. Depending on your material this could be your finished part. In my case the material would warp in the sun. So proceed to step 5)
5) Dry-fit your part into your vehicle, make any necessary changes. Finish out your RP (rapid prototype) part with primer to 600 grit sandpaper. The A-surface of this part should be ready to paint, but you will not paint it. Proceed to step 6.
6) Gain access to a casting shop that has RTV Silicone and a nice vacuum chamber. You should apprentice in this shop for a few months because molds are tricky. Make a silicone mold of your RP part paying special attention to the A-surface which you sanded in step 5. The silicone will pick up whatever resolution you sanded to.
7) Pour polyester resin into your mold to produce the finished part.
8) Pour another part because you got too many air bubbles in the first one.
9) Repeat step 8 until you get a good part. Also, go back to step 6 and put on your respirator and gloves.
10) paint and install. If you made a nice mold and resin part, there will be no sanding required. Every part you pour from the mold will be ready for paint. Or you can cast a colored part, or a clear part, or a part with sparkle glitter if that's your thing.
I guess I should have taken photos along the way...
Old 04-19-2007, 05:34 PM   #9
Jakiii's Avatar
It is a US civic. My center panel is identical to yours but the Si has the lower shifter panel where yours has a switch panel and console. As far as I know this center panel is common to all EP civics (2001-2005).
Old 04-19-2007, 06:05 PM   #10
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
That is one freaking awsome work.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 04-19-2007, 06:23 PM   #11
I knew it was that easy. Thanks for the info, time to go to school for some 3D work!
Old 04-19-2007, 07:39 PM   #12
GoHybrid's Avatar
how well connected must you be to get your hands on that? who do you even ask?
Old 04-20-2007, 02:17 PM   #13
The controls and radio area look the same but the emergency flasher is also down in the shifter area where mine is between the air vents.
We had some SLA's done at another company I worked for but I don't remember what they cost. Just for grins, what would it cost you to run some more?
Old 04-20-2007, 02:39 PM   #14
turbocad6's Avatar
once the work is done, I would imagine pumping out copies is cheap, but to have something like this done from scratch for you for 1 piece has to be major big $$$$$$$$ no doubt,
I'd have to guess well over $500 considering all involved, & I wouldn't be too surprised if it was several times that really
if this kinda thing was affordable & practical on a one-off basis I could think of a ton of things I'd love to have done.... I think the only reason this one got done this way is because this guy just happens to be in a situation where he has these resorces available to him at his job... man, that must be nice
Old 04-20-2007, 05:00 PM   #15
Jakiii's Avatar
Many Rapid Prototyping vendors are sprouting up that will make a one-off piece for you. I will try to get a direct quote but I'm guessing a bezel would cost about $200 - $300 output in ABS plastic. This would save having to make a mold because ABS can be used directly in a vehicle. I wanted to make more than one part so I made the mold. But the potential exists for hobbyists like us to create 3D CAD parts and output them through vendors like XPRESS 3D: http://www.xpress3d.com/
AutoPage 860 + 2000 Honda Civic Wiring diagram Help! pcmofo Hardware Development 4 01-14-2007 07:19 PM
need help 2004 honda civic deck swap timrock Car Audio 11 08-28-2006 11:03 PM
Installing line out converter in 2006 Honda Civic? buzz4life85 Newbie 2 07-11-2006 10:50 PM
93 Honda Civic Dvd/Mp3/Lcd Install civicduties Show off your project 9 01-17-2004 04:11 PM
install on a 95 honda civic schrodos General MP3Car Discussion 7 11-21-2000 05:43 AM
