The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Display Modes
Old 07-01-2007, 10:40 PM   #1
Grimoire's CarPC Specs
Grimoire's Avatar
Vehicle: 2003 Pontiac Vibe GT (Dent is fixed! XD
My Photos: (0)
Carpeted Fiberglass Amp Box for Vibe GT
Alright, talk about frustration...
I dont know about the other states, but NC gets bloody hot. I have my Amp under the 'hidden' floor in my Vibe and it was getting well above 100F in there. The amp stopped once, and that was enough for me. I made a box with 3 fans. 2 blowing in, 1 blowing out. It is MDF frame, with Fiberglass coating. I was going to paint it, but then, nah ...its carpeted. Im better with carpeting. Also, I will NOT drive without my Spare tire, so I had to get that to fit in there as well. I know it may look tacky but damned if I drive and BLAMMO, Im on the side of the road with a flat...But hey, Ive got tunes and a DVD player... XD
So, Pics... The beginning
I know I know, vacuum..... But I was in a rush and trying to finish!
Grimoire is offline   Reply With Quote
Sponsored Links
Old 07-04-2007, 11:27 AM   #2
Wants to make it harder
monkeyracer's CarPC Specs
monkeyracer's Avatar
Vehicle: 2007 PT Cruiser Touring
My Photos: (63)
Looks nice, have you noticed that it helps? (The fans?)
I had a similar problem with mine, Lately Denver has seen near record high temps, and the amp is in the trunk with no A/C. My amp (and most) has a temp protect circuit, so if it gets hot, it cuts out, and comes back on when temps decrease. Quickly the amp would turn off and on after maybe 10 minutes of music, and it became very annoying (not to mention the extra wear possibility...) so I got a pair of fans and made a pedestal of sorts for it. Basically the amp is on top of the "box" yet, the box only has four of the six sides, the bottom and left and right are MDF, the amp is the top piece, and the front and back are open for ventilation. This helped, but hasn't completely solved the problem, it doesn't cut out often, but when it does, it's just as annoying. I end up folding forward the seat back, and letting the A/C flow into the trunk, and the hot air out.
I may change the design so the fans blow onto the amp's heatsink instead, maybe that will help...
Any work on the other side sub enclosure?
2007 Chrysler PT Cruiser TE
Car PC Progress:
Planning.......[---------X-] 90%
Fabrication...[--------X--] 80%
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
monkeyracer is offline   Reply With Quote
Old 07-04-2007, 01:00 PM   #3
Grimoire's Avatar
My Photos: (0)
YES! A huge improvement! Its a little noisy but once the music starts playing you can barely hear it. I also dont hear any static on the line or any interfeirence(sp) from the fans themselves.
No, I have not started on the other sub box, waiting for some finances to catch up. The Amp Box was spare MDF and Fiberglass, so it was pretty much free! I will be starting on it after the 15th though. And with the mistakes I made on the first one, I hope this one comes out much better, I have some ideas Id like to try out and if they pan, then Ill redo the first one I did. Ill say one thing, while I was wiring the Amp box, I had to remove the sub, I noticed a small hole, once I covered that, wow, HUGE sound difference. I guess that sealed REALLY is a lot better!
Sponsored Links
vB code is On
Trackbacks are Off
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 02:41 AM
Could my amp be bad or did i miss something? sansoo24 Car Audio 20 03-05-2007 01:45 AM
3/4 inch Plexi Glass/Diamond Plate Amp Box lostreception Fabrication 6 03-20-2005 08:15 PM
FS: 2 mtx 10 inch subs and 400 watt amp with box xdjxklusivex Classified Archive 0 02-25-2005 03:41 AM
Fiberglass Sub Enclosure project shillier Fabrication 25 09-10-2004 06:15 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
