Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 07-16-2007, 12:40 PM   #16
VmtSquad's Avatar
VmtSquad is on a distinguished road
Here's my advice, I would try to find or order a door for the glovebox and then make a costum MDF mounting recovered with some leather behind the door. That way you could close the glovebox and HIDE everything...OEM looks when closed.
Theres a bounce of thread where you can learn how to make some nice MDF boxes, try google ...there's always something good!!!
Good luck and keep us updated!
VmtSquad - I sold my soul to Honda!
Final Install
CarPC progress: 95%
VmtSquad is offline   Reply With Quote
Old 07-17-2007, 12:25 AM   #17
ayetothedea is an unknown quantity at this point
finally some good advice. much appreciated. ill look that stuff up for sure. appreciate the help. talk to u guys sooooon
-AD
ayetothedea is offline   Reply With Quote
Old 07-17-2007, 08:09 PM   #18
just bought a glovebox door.....so.me and my buddy are going to work with that. ill prolly post pics and updates on how it goes. thanks for the help
Old 07-22-2007, 10:16 AM   #19
Mikeyd08 is an unknown quantity at this point
most cars have the cabin air filter behind the glove box. check your forum or w/e you use to make sure its not behind the glove box because if you need to replace one [every 30k (for mazda6) dependin on the car] youll have to take the whole SOB out which i could guarentee wont be a fun job.
just somethin to think about
2006 Mazda 6
12" elemental design 13kv2
9.2 Amp
pioneer 6x8's
boltons..
future mod: my first car PC
Mikeyd08 is offline   Reply With Quote
Old 07-22-2007, 11:00 AM   #20
so ur saying that if i fiberglass the glovebox door with a screen, there will be no air flow through the car? my blower for the heater is busted anyways but i was planing on getting that thing fixed for the winter. dont understand
thanks
_AD
Old 07-22-2007, 01:01 PM   #21
red_parchel's Avatar
red_parchel is on a distinguished road
he's suggesting that you may have an air filter behind the glove box that should need to be replaced if it gets dirty, it's a maintenance thing, so if you had such a situation, i would suggest making your glove box door still open as it used to, dont fiberglass it shut.
Carputer Status:
MobileOne: retired - via - Gentoo Linux, gps drive, nGhost, tethered e815
MobileTwo: retired - via - Ubuntu Linux, gps drive, nGhost
MobileThree: development - Intel Atom - Gentoo Linux, iGuidance3, navIT, nGhost2
--worklog--
red_parchel is offline   Reply With Quote
Old 07-22-2007, 07:53 PM   #22
yea. we were ganna put fiberglass over the door, but still allow it to open. problem solved. thanks guys
Old 07-22-2007, 08:51 PM   #23
VENDOR - Nexations Creations
Nexson's Avatar
Nexson is on a distinguished road
Well, I got to this thead late but would still like to offer my advice. get some wood and build a frame that fits into that section, once it fits in there good with about 1/8'' gap all along, I would take the screen's bezel and use wood dowels or pop sicle sticks to hold the screen in place where you want it, then stretch your fleece over it and resin it. Then the process just follows of adding glass/bondo sand prime paint.
Also since you want to make it removable, I would suggest using industrial strength velcro, velcoing the back of the frame you made and velcroing the actual metal where the glove box would sit, this way it stays in place well, and will still be removable.
EDIT; Just read u got your glove box.
Nexson is offline   Reply With Quote
Old 07-22-2007, 09:47 PM   #24
^^^^ acually, GREAT advice, i appreciate it. ive been checking out this thread on the s10 forums
http://www.s10forum.com/forum/f26/te...nd-two-208071/
it helps a lot. i dont understand wat u meant tho when u said popsicle sticks, how would those hold it in place? i could make it so the screen is in there forever, but not sure if i want to. thanks guys
-AD
any input would be helpful
**EDIT: just realized that u JUST REALIZED i got a glovebox door. What would u do then with that?? sorry and thanks
Old 07-22-2007, 10:06 PM   #25
Nexson's Avatar
oh, you would glue the bezel of the screen with the popsicle sticks, then you stretch the fleece over everything and resin it, the resin makes the fleece as hard as a rock. I am not sure how much you know about glass, so it is kinda hard to explain things in depth, but with the glove box, that is a cake job, I have done some just like that, but not for a s-10, just cut the glue box and CA glue the bezel in place, sand it all down, bondo, primer, paint.
hit me up
exus28 AIM, if you need more help, this has been my profession for a couple years, so i could probably lend u a brain
Old 07-22-2007, 11:34 PM   #26
^^Thank You
Old 07-22-2007, 11:35 PM   #27
hey i just wanted to thank you for posting that link to the s10 forum, that is exactly what i was in the middle of doing to my blazer (Same dash) .. wish i had found it 2 months ago, but thanks again!
-red
Carputer Status:
--worklog--
Old 07-23-2007, 12:12 AM   #28
Nexson's Avatar
hey sry missed your IM, I added you to my budyd list, catch online
Old 07-23-2007, 12:51 AM   #29
-red
yea man, no prob. someone sent it to me and i was REAL glad to find it. its a little diff. from my project, but helps me get the idea. good luck
-AD
Old 07-28-2007, 01:33 AM   #30
going to buy supplys SAT. and starting project SUN. ill hopfully have pics to show.thnks
Glove box mounted laptop DVD-ROM using 15 foot IDE cable pics. LESLIEx317537 General Hardware Discussion 7 01-08-2004 02:03 PM
2000 Chevy Tracker Glove Box PC nijel Show off your project 6 11-16-2003 09:04 PM
Glove Box Case bjm2020 General Hardware Discussion 3 06-05-2003 03:09 PM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 03:16 AM
Laptop/LCD screen hookup... UrbanTacticz LCD/Display 1 11-28-2001 06:49 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
