Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 07-19-2007, 10:20 AM   #1
TonyWare's Avatar
TonyWare is infamous around these parts
Brake fluid vs. sanding
I read that brake fluid is a pretty effective paint remover. No, I haven't tried that yet - lol - but I was wondering if it is better than sanding that tends to also remove layers of the painted plastic ? Has anyone adopted that method of paint removal while working on their fabrication ?
TonyWare is offline   Reply With Quote
Old 07-19-2007, 10:22 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
media blasting.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 07-19-2007, 10:26 AM   #3
fixerofallthing's Avatar
fixerofallthing is on a distinguished road
It will eat plastic as well. Do not try it on plastic. On metal it does eventually remove paint but it is not a recommended practice.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 07-19-2007, 10:31 AM   #4
TonyWare's Avatar
My main concern is that it is not the most environmentally friendly way of doing things (actually its pretty bad!) ... but a friend suggested to dip my bezel in it for a few hours instead of sanding it to re-do it and I was doing some reading about brake fluids. I had no idea how toxic that stuff is.
Old 07-19-2007, 10:38 AM   #5
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Why not just use paint remover?????
Enforcer is offline   Reply With Quote
Old 07-20-2007, 09:01 PM   #6
redls1bird's Avatar
redls1bird is on a distinguished road
Be carefull with paint remover. It will eat alot of plastics and even worse, burns like a son-of-a if you let it sit on your skin too long.
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
redls1bird is offline   Reply With Quote
Old 07-20-2007, 09:55 PM   #7
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
Brake fluid does the same thing too. It is not very friendly towards plastic. Also if you don't get all the of brake fluid residue off, the paint won't stick.
Even though it takes longer, sanding is the safest and best way to remove paint from plastic.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 07-23-2007, 06:20 PM   #8
moogvo is an unknown quantity at this point
Why not just scuff it up with a scotchbrite pad and paint it whatever color you want it to be with Krylon Fusion paint?
Just a thought.
moogvo is offline   Reply With Quote
Old 07-23-2007, 06:38 PM   #9
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
the only safe way to remove paint from plastics with chemicals is to use a "bumper stripper", aresol can available at body shop supply stores, safe on most plastics, but in being so, also not very agressive in the paint stripping area, but does the job.
still, I'd say sanding is the way to go here, if the finish has good adhesion & is compatable with the new top coat no reason to even remove it all 100% either...
turbocad6 is offline   Reply With Quote
Old 07-23-2007, 10:11 PM   #10
TonyWare's Avatar
Just a thought.
Sanding did the job fine. I'll check out the "Krylon Fusion paint" in the next custom screen iteration (someone who saw mine wants his ACcord done too $$$ lol), but in the meantime I used Tremcald Textured Paint and it looks pretty good. Also looking for vinyl finishing products. That is way out of my leauge so I am also looking for a vinyl pro who knows what he is doing. Yes, I guess the brake fluid is an over kill if you think about the more practical alternatives. Thanks for the advice guys.
Where is the parking brake wire? JasonMK Newbie 2 07-16-2007 12:00 AM
Sanding Techniques Sonicxtacy02 Fabrication 13 02-13-2006 07:24 AM
Finally started my dash fabrication... need tips on sanding... wardemon666 Fabrication 15 09-22-2005 09:31 AM
Sanding dash, need help! mazda3uzr Fabrication 10 12-22-2004 06:27 PM
cleaning brake calipers magnetik Off Topic 4 03-31-2003 12:41 PM
