Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 09-25-2007, 08:39 AM   #1
0828546333 is an unknown quantity at this point
Talking Fiberglass subwoofer box.
Hi Guys
I decided to make a Fiberglass sub box for my tazz and share my experiance as a tutorial.
This is how it came out.
What you need:
11L of Fiberglass resin
Hardner
6m of Fiberglass mat
5 Roles of thick Masking Tape
10 meters of Foil
Thinners
Brush
Wood
Stretch material
Carton Boxes
BodyPutty
Spot Putty
Paint
Wooden round sticks
Sanding Papper
And you need alot of paitance for the job ahead!!!. And you are going to itch a lot!!!
Firstly I took out my old Box.
Because I did not want to struggle to take out my spare wheel I
decided to mount it to the back of my Back seat, so that when I
leaned the seat forward I could easy retreive the wheel.
I cutted out the shape of the wheel in the base wood.
Then I started to build out of carton box for the moulding of the Fiberglass.
Just for curiosity I then placed all my equipment in to see how it would fit best.
Then I started to apply the whole trunk spase with masking tape.
After the whole trunk had masking tape inside I covered that with a layer Foil.
Note: You have to do this to be able to remove the moulded Box.
And believe me with all the precausions I took I struggled to remove the box!.
I then started to paint Fiberglass mat and ressin to get the inside mould of the trunk.
After 3 layers of Fiberglass you can remove the fiberglass mould from your trunk.
Now you must apply3 more Layers to the box.
With a permanent marker you can scetch where you need to cut off the excess fiberglass
Now you can do a test for fitment.
Cut out the rings for the Subwoofers and see if thei fit.
With the round wooden sticks make a placement for your sub rings. I
used a gluegun for the job. Use enough glue for this step or else the
frame will break when you pull over the stretch material.
I then placed the subs in the wooden rings to see if my trunk still
closes.
Now you can stretch the cloth over the box and be sure you
use enough glue on the sides t secure the moulding.
Also note that when you glue on the sides that you go way down
because when you apply ressin over the cloth it will pull loose.
Now start you can start to paint on ressin to the cloth. I think it is called fleecing.
The fleesing is not strong enough for the box.You need to put 5 to 7 layers
of fiberglass and ressin to complete the prosess.
Now for the hard work...
Now you have to sand off the excess fiberglass and apply Bodyputty and also
need to applie spotputty for small bubbles.
I sanded about 18 hours for the right result.
Cut out of wood the back board and the board that comes over your amps.
The bottom wood I just carpeted.
After all the sanding and hard work I ended up with this.
C&C are welcome or any quistions. O Yey exquise my English I spoke it since I was Twice,,, he he
0828546333 is offline   Reply With Quote
Advertisement Sponsored links
Old 09-25-2007, 08:57 AM   #2
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
good job and nice tutorial!.. my only question is your design.. you have two ports pointed directly at each other. Wont that cause all sorts of frequency distortions?
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 09-25-2007, 09:00 AM   #3
I dont actualy know, It sounds perfectly fine to me.
Old 09-25-2007, 09:59 AM   #4
Dennis5587's Avatar
Dennis5587 is on a distinguished road
great first post!!!
And good job on the trunk, where did you put your other amp?
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Dennis5587 is offline   Reply With Quote
Old 09-25-2007, 10:04 AM   #5
Dennis: The other amp is underneath the Top one, It is seperated by a piece of Wood.
Old 09-25-2007, 10:33 AM   #6
Mr Beta is on a distinguished road
Mad props on this one. Love what you did with the spare tire.
Thumbs up.
Mr Beta is offline   Reply With Quote
Old 09-25-2007, 11:23 AM   #7
AJ3000's Avatar
AJ3000 is an unknown quantity at this point
nice install man, defo given me some ideas for the woo of doom. sick props to thee
East Coast Audio UK
Daewoo Lanos "Woo of Doom" Show Car
Fabrication 4%
Bodywork 0%
carputer 1%
Finish Line - not even in sight!
TOTAL SPENT SO FAR £250
AJ3000 is offline   Reply With Quote
Old 09-25-2007, 11:27 AM   #8
Kimota's Avatar
Kimota is on a distinguished road
Great job, very original
Kimota is offline   Reply With Quote
Old 09-25-2007, 12:31 PM   #9
Scoop is an unknown quantity at this point
Thumbs up
Nice install! All the effort you put into it paid off. How long did it take total?
Scoop is offline   Reply With Quote
Old 09-26-2007, 01:59 AM   #10
Well, it almost took me a month, but I could of been much sooner, I waited for more cash and offtime so that I could finnish the project.
Old 09-26-2007, 05:50 PM   #11
kazzxtrismus's Avatar
kazzxtrismus is an unknown quantity at this point
supa sweeet
06 Altima..SER front bumper.
CAR PC.....soon to be true!!
Oshawa Canada!!
kazzxtrismus is offline   Reply With Quote
Old 10-18-2007, 09:19 PM   #12
bud_man13 is an unknown quantity at this point
what kind of foil did you use? was it just aluminum foil or like plastic wrap?
bud_man13 is offline   Reply With Quote
Old 10-19-2007, 02:07 AM   #13
It was aliminium foil. You just have to be sure that underneath the foil you have enough masking tape, so that the resin does not penitrate to your interior.
Old 10-19-2007, 11:12 PM   #14
maxgtr2000's Avatar
maxgtr2000 is an unknown quantity at this point
Good job on that, I like that idea for the full size spare cause donuts suck.
maxgtr2000 is offline   Reply With Quote
Old 10-21-2007, 12:12 AM   #15
DodgeCummins's Avatar
DodgeCummins
Real nice explanation on how to fiberglass!
current projects
DodgeCummins is offline   Reply With Quote
Custum Fiberglass Work Needed? MKruluts Fabrication 2 11-01-2006 08:18 PM
False floor i3igmind Fabrication 29 02-04-2006 11:28 PM
Subwoofer Box Enclosure (Technical Questions, not "how do I make this") Epon Car Audio 28 01-17-2006 07:58 AM
What do you think of this subwoofer box for Ram Quad Cab? boyd98 Car Audio 2 12-05-2005 11:13 AM
Case design for a stowage box. nibix Fabrication 3 07-10-2004 06:12 PM
