The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Display Modes
Old 09-26-2007, 10:37 AM   #1
Vehicle: 91 300ZX Twin Turbo
My Photos: (0)
Flush mount help plz.
I am working on installing a flush 8" screen into my 300ZX. The screen I have is listed below as well as the spot I am looking for it to go into.
I am going to have to remove the casing of the screen to mount it into place as I just dont have the room w/ the casing.
Has anyone ever done this? Any pictures or info on how to do this?
Here is a pic of the screen:
Here is the location I want it to go in:
SoloCon is offline   Reply With Quote
Sponsored Links
Old 09-26-2007, 10:59 AM   #2
nst6563's CarPC Specs
Vehicle: 2004 Nissan Maxima
My Photos: (0)
Looks like there's a clock there at the bottom below the HU. Do you really need that? Since there looks to be one on the HU as well? My vote would be to take the clock out, move the HU down to where the clock is, and use that space above to mount the screen.
Mounting flush shouldn't be a problem since it looks like you'll have ample space depth-wise there. You'll definately need to use some sort of 'filler' or compound to make it look good though.
What you'll need to do is take measurements of the screen both in and out of it's casing. Then take measurements of where you're wanting to put it. Play around until the numbers line up and then use that as a starting point.
nst6563 is offline   Reply With Quote
Old 09-26-2007, 11:22 AM   #3
My Photos: (0)
Thanks for the feedback.
I cant remove the clock as a turbo times will go there and there is not much room in the back of it. I will be removing the desk (CD palyer) the pocket and the AC vents and would want to mount the screen there. How do I make the screewn flush w/o messing up the glass screen?
Also, anyone seen these mounted flush w/o the casing?
Old 09-26-2007, 12:09 PM   #4
AJ3000's Avatar
Vehicle: 2001 Daewoo Lanos 1.4i SE
My Photos: (0)
hit the stickys on such things and check the worklogs, as this has been convered a heap of times. spoonfeeding is for suckers!!! keep us posted with progress, i'll be interested to see how it turns out!
East Coast Audio UK
Daewoo Lanos "Woo of Doom" Show Car
Fabrication 4%
Bodywork 0%
carputer 1%
Finish Line - not even in sight!
TOTAL SPENT SO FAR £250
AJ3000 is offline   Reply With Quote
Old 09-26-2007, 02:33 PM   #5
My Photos: (0)
I have no problem searching, infact, I have searched many times. What "stickys" have you seen?
Old 09-26-2007, 05:57 PM   #6
My Photos: (0)
I think he means these:
http://www.mp3car.com/vbulletin/fabr...ory-bezel.html
http://www.mp3car.com/vbulletin/fabr...sing-tips.html
http://www.mp3car.com/vbulletin/fabr...dvd-drive.html
Old 09-27-2007, 04:14 AM   #7
AJ3000's Avatar
My Photos: (0)
East Coast Audio UK
Fabrication 4%
Bodywork 0%
carputer 1%
Sponsored Links
vB code is On
Trackbacks are Off
KITT - It had to happen sometime! prefim MediaCar 34 10-25-2007 03:23 PM
Flip Out Versus Flush Mount Maheriano LCD/Display 19 06-27-2006 01:19 PM
What materials needed to flush mount Xenarc? Will Albers Fabrication 1 01-28-2005 04:03 PM
How am I going to mount this DSCustoms screen flush in my dash? (Pictures) smoldyr LCD/Display 34 02-29-2004 02:14 AM
Flush Mount Screen Needed! bjm2020 LCD/Display 10 02-19-2004 11:08 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
