Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 10-04-2007, 12:37 PM   #1
sdashiki's Avatar
sdashiki is on a distinguished road
Machining something really small, really cheap? Canada?
If I needed, say, a 1mm square piece of metal a few inches long, how easy is that to machine?
Basically I need a Robertson Square screwdriver. Which is ubiquitous in Canada, but not here in the US.
They come in standard sizes, #00 being the smallest.
however, I can not find a single place that sells #00, only #0 sizes.
Since the screwdriver would basically be just 1mm x 1mm x 5 inches or something, how difficult would it be to just machine from a larger square stock?
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
sdashiki is offline   Reply With Quote
Old 10-04-2007, 05:38 PM   #2
seanz0rz's Avatar
seanz0rz is on a distinguished road
well im guessing you want tool steel, so its going to be expensive.
how about this?
http://www.mcmaster.com/itm/find.ASP...string=2634T14
and then you can cut it to roughly the correct amount, and then finish sand it.
i looked around for 00 robertson, cant find anything either.
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline   Reply With Quote
Old 10-05-2007, 01:14 AM   #3
dblair is an unknown quantity at this point
I don't think I've ever seen a robertson screw or driver as small as that. Maybe you could contact the robertson company ask what retailers are selling the #00 driver. http://www.robertsonscrew.com/
dblair is offline   Reply With Quote
Old 10-05-2007, 10:43 AM   #4
sdashiki's Avatar
I looked a bit more into it. the #00 is still too large.
1mm x 1mm is probably a proprietary size.
I dont know if I need high class metal to make it, seeing as how its so small and under little stress from the nature of the slot.
(----) 0.0%
Old 10-08-2007, 08:26 PM   #5
PAlice is an unknown quantity at this point
Have you found your screw driver yet. Would take much. Just take a 00 driver bit and mount it on an indexing fixture and five minutes of grinding time. Any machine grinding shop can do this simple operation.
PAlice is offline   Reply With Quote
Old 10-10-2007, 05:43 PM   #6
kazzxtrismus's Avatar
kazzxtrismus is an unknown quantity at this point
some folks in the states call the square recess...but 1mm is propriotary...try getting a small flat head in there.(corner to corner)...at that size it should work free.
i'd send you whatever you need from here in toronto...just say the word
06 Altima..SER front bumper.
CAR PC.....soon to be true!!
Oshawa Canada!!
kazzxtrismus is offline   Reply With Quote
Old 12-06-2007, 12:01 AM   #7
trevorcalgary is an unknown quantity at this point
Check with a really good Klien tools retailer... this sounds like the yellow dot robertson that many old telephone construction guys had in their tool belts. In the tel/elect trade it would have been a #4 (i think that is 0 in other schemes)
T
trevorcalgary is offline   Reply With Quote
