Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 12-06-2007, 08:44 AM   #16
americasfuture2's Avatar
americasfuture2 is an unknown quantity at this point
so get it professionally done? i dont have the right area to do anything more than a rattle can job. any chance of the stuff fading or flaking off like i have seen on a lot of rice?
Gathering parts----99% (I'll always want something else, its never 100%)
Using and programming in RR 3.14% (I need tons of help on this one!)
First Actual 98 Blazer LT Install
First 08 Aveo5 SV Install
87 Fiero GT waiting
americasfuture2 is offline   Reply With Quote
Old 12-06-2007, 09:22 AM   #17
thekl0wn's Avatar
thekl0wn is on a distinguished road
Personally, I'd rather pay to have it done over rattle-canning it. The fading will come from the quality of paint, and the UV protection in/on it. The flaking would be either from bad prep, bad prime, or not using a plasticizer in the paint/primer.
Planning [----X-----] 40%
Programming [-X-------] 20%
Parts [-----X----] 50%
Install [X--------] 5%
See Me In A Pink Skirt
thekl0wn is offline   Reply With Quote
Old 12-06-2007, 12:02 PM   #18
dundidit is an unknown quantity at this point
Yeah, and sem stuff vinyl dye. What he is painting is hard plastic. It doesn't require dye. Dye is also harder to spray and its going to eventually come off( even with adhesion promoter). I am not a fan of the stuff either. Its just a good CHEAP fix. Thats not really that cheap anymore. The great thing about letting someone else do it is they have to fix it when it messes up because of years worth of armor all thats on it.
dundidit is offline   Reply With Quote
Old 12-06-2007, 12:07 PM   #19
they hafta fix it and if they **** it up, they hafta replace it. and they have millions onf years of experience on doing it. and i have like 15 minutes of experience.
87 Fiero GT waiting
Old 12-06-2007, 12:14 PM   #20
Probably will not be that expensive to get done.
Old 12-06-2007, 12:56 PM   #21
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
It might just be easier to get a cheap $15 airbrush if you have a compressor for air tools. Mixing it yourself isn't that hard if you can't get it from the auto paint store.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 12-06-2007, 12:57 PM   #22
i have an airbrush, havent used it yet. no compressor. and again, no where to paint
87 Fiero GT waiting
Old 12-06-2007, 01:59 PM   #23
thekl0wn's Avatar
In the end, for one project, you're going to have better luck, and spend WAY less having someone else do it. You're looking at primer, paint, clear, thinner, catalyst, adhesion promoter, wax & grease remover, and plasticizer as the needed chemicals if you were to sand/smooth and gloss finish the entire piece. (remove primer & clear for OEM look) Combined, that's a fair amount of products, whereas an automotive paint shop is going to have all of this, or at least 90% of it, and would be able to churn it out in a day or two for you.
Old 12-06-2007, 06:37 PM   #24
it has no paint. its all the color of the plastic. im not wanting to smooth it or anything. that peice is too much of the dash to smooth. i think in the end, i will like that i spent the extra $$ to get it professionally done with all the proper quality materials and many years experience compared to my 15 minutes.
87 Fiero GT waiting
Paint Clarifications ctsoccer13 Fabrication 3 06-15-2007 12:14 AM
To paint or not to paint cavramair Car Audio 17 05-21-2005 03:59 PM
SEM paint Quattro Fabrication 9 04-09-2005 03:00 PM
Very Unique Bondo Problem! Paint Screwing it up? Grayscale Fabrication 24 01-09-2005 12:34 PM
How do i connect carputer audio to my Stock system minus stock HU? Sporttracguy Newbie 13 08-22-2004 05:52 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
