The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Display Modes
Old 11-23-2007, 01:34 PM   #1
My Photos: (0)
Carputer in AC box under dash in RX7
Well I was trying to fit the custom box that I made for my carputer to fit under the dash where my AC box was, but only to find out that I couldn't reduct the air from the blower to the heater core easily, so then it struct me, gut the inside of the ac box, then slam the computer in there. The car blower will act as a cooling fan for the computer. And also the sweet thing is even if the heater is on, because it is ducted after the AC box, it will always be cold air blowing through it.
dj55b is offline   Reply With Quote
Sponsored Links
Old 11-23-2007, 01:42 PM   #2
JimmyFitz's CarPC Specs
JimmyFitz's Avatar
Vehicle: 2002 Thunderbird V8
My Photos: (0)
Condensation issues?
You may be asking for problems with condensation.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 11-23-2007, 02:25 PM   #3
h3rk's CarPC Specs
Vehicle: 2006 Nissan Altima
My Photos: (0)
Probably, as air is typically 32-40F coming out of the evap. Turn off the car and presto, instant rain.
Make sure the condensation drain wont get plugged, but I'm not sure that will save you.
Did you read the PC cooling FAQ?
h3rk is offline   Reply With Quote
Old 11-23-2007, 04:54 PM   #4
Vehicle: 94 Mazda RX7
My Photos: (1)
I'm working on RX-7 carPC, but my plan is to fit everything into one double din box. I have case made and it looks like it will work. Tight, but will work
katit is offline   Reply With Quote
Old 11-23-2007, 05:04 PM   #5
Deric's Avatar
Vehicle: 2006 Ford Mustang Coupe
My Photos: (0)
+1000
I would look for an alternate location. Water + Electronics = POOF!!!
Deric is offline   Reply With Quote
Old 12-28-2007, 10:30 AM   #6
LinuxRacr's CarPC Specs
LinuxRacr's Avatar
Vehicle: 01 Turbo Mazda MP3
My Photos: (0)
Unless they don't plan to use the A/C?
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Starting over again with new build! Here
Completion Progress Bar: [*********99%]
LinuxRacr is offline   Reply With Quote
Old 12-31-2007, 02:07 PM   #7
FLAC is for flaccid
parksgm's CarPC Specs
parksgm's Avatar
Vehicle: Mustang GT
My Photos: (4)
seal the computer in an airtight box in the ac compartment. Bingo.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 12-31-2007, 03:12 PM   #8
h3rk's CarPC Specs
My Photos: (0)
then the airtight case would have to be a pretty good cpu heatsink as well (or something like that, beyond that small heatsink and fan), and have enough external surface area to remove that heat. Since that solution would make the computer's internal air cooling a closed system. And radiant and conduction heat transfered from the air inside the box through the airtight case to the air outside the box(cooling) would be much less than which would be achieved with an open system.
Old 01-03-2008, 12:07 PM   #9
Vehicle: 1999 Toyota Solara
My Photos: (0)
If I understand this correctly, I believe he is not using the AC. He is only using the blower. Therefore there shouldn't be much of a condensation problem since it will always be ambient air. However, from the pictures, it looks like the air flow is almost completely cut off by the PCI card. I don't think he's going to get much use out of the blower or cooling for the computer that way. Just my $0.02.
Profozone is offline   Reply With Quote
Old 01-03-2008, 01:20 PM   #10
FLAC is for flaccid
parksgm's Avatar
Vehicle: Mustang GT
My Photos: (4)
Great point.
Sponsored Links
Old 05-23-2008, 09:08 AM   #11
My Photos: (0)
wow ... totally forgot about this forum for a while ... yes the AC is out and not using it, its Canada we all live in Igloos :P. Yes the blower has been restricted by the PCI card, but it all works great, I've had the thing in the car for about a month now and with it raining and stuff and not a single problem.
Sponsored Links
vB code is On
Trackbacks are Off
Carputer TIME!! please HELP!! CoupeE46 Newbie 4 11-26-2006 05:52 PM
F/S: JL 12w7 Subwoofer with box!!! Pictures inside neema12 Classified Archive 10 08-29-2005 08:45 PM
mini box for carputer idea? *DaNut* Newbie 1 10-13-2003 09:40 PM
AC cooled Carputer? Pogi General MP3Car Discussion 25 10-09-2003 11:18 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
