Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 02-17-2008, 10:39 PM   #16
VENDOR - Nexations Creations
Nexson's Avatar
Nexson is on a distinguished road
thanks!
Nexson is offline   Reply With Quote
Old 02-18-2008, 09:37 AM   #17
mnapoles's Avatar
mnapoles is on a distinguished road
nexson you are in the v6p.net forums as well arent you? the name and 1/2 dins sound prettttty familiar
2003 Honda Accord EXL-V6
*MY INSTALL THREAD*
mnapoles is offline   Reply With Quote
Old 02-18-2008, 01:50 PM   #18
Nexson's Avatar
Yes, that is me!
Old 02-19-2008, 01:10 AM   #19
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
I don't know if you're interested in production work, rather than custom fabs, but here's a thread that might be interesting:
http://www.mp3car.com/vbulletin/fabr...din-mount.html
Where in Florida are you?
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is online now   Reply With Quote
Old 02-19-2008, 11:50 AM   #20
Nexson's Avatar
Another Xenarc I just finished!
Old 02-19-2008, 01:53 PM   #21
mnapoles's Avatar
damn.... do you ahve a core charge? lol
those came out much better than the one i made for my 03 accord coupe.... wanna make one for my lilliput with a built in slotload? PM me a quote
*MY INSTALL THREAD*
Old 02-20-2008, 08:42 PM   #22
Nexson's Avatar
Yea man, hit me back up so we can discuss!
Old 02-20-2008, 09:25 PM   #23
Morpheus2010 is an unknown quantity at this point
hey Nexson what size is that xenarc and how bright is it compared to my shark. Good news gooddeals18 will exchange my monitor out. I just have to get you to take it out.
Morpheus2010 is offline   Reply With Quote
Old 02-20-2008, 09:48 PM   #24
Nexson's Avatar
7in, brightness is a little bit better.
Do you need to send your old screen back in first?
Old 02-21-2008, 01:02 AM   #25
Bimmerstyle's Avatar
Bimmerstyle is on a distinguished road
You do some amazing work! Really, it looks very OEM!
Thanks for sharing the texture paint you use. I never found good texture paint over here in Belgium. Now I found a SEM dealer in the Netherlands wich is not too far for me.
I work part time at my friends bodyshop installing audio systems. Since we both have a Car PC in our car, customers see them and also want one. So I will be installing some screens in the near future so it's good to know were I can get some decent texture paint. Thanks!
BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
Bezel Worklog-My Install -iDrive F01 RR Skin
Bimmerstyle is offline   Reply With Quote
Old 02-21-2008, 02:45 AM   #26
shreyasma's Avatar
shreyasma is an unknown quantity at this point
Mindblowing
shreyasma is offline   Reply With Quote
Old 02-21-2008, 02:48 AM   #27
shreyasma's Avatar
how did you get so many ideas???
Are you having spinach or are you on some brain steroids??
Old 02-21-2008, 11:14 AM   #28
krnpimpsta's Avatar
krnpimpsta is an unknown quantity at this point
Dude, that's some flawless work. What material are you using to create the bulk of that single gauge pod in this picture?
2008 Mustang GT CarPC
krnpimpsta is offline   Reply With Quote
Old 02-21-2008, 11:18 AM   #29
krnpimpsta's Avatar
And if you don't mind my asking, what about this white stuff here? Is that just fiberglass or some kind of putty?
Old 02-21-2008, 12:22 PM   #30
Nexson's Avatar
Yea, a can of the texture is $25 a shot, so it is pretty expensive, it is also very hard to work with, everytime it is sprayed, it needs to be sanded down smooth so the texture still exsist but the surface is not rough. I found that 400 grit does the best job for making this happen!
I might be lol. Some of the ideas come from me and others come from the customers themselves, from here I make it happen, IF it is do-able.
First I took fleece and stretched over my structure, from here I used resin to make this soft fleece, hard. once you reach this point you have to add fiberglass mat which is what you see in the pictures. The fiberglass mat gives the pod strength. Sand down after every layer and reaply the fiberglass mat.
In this picture of the process no putty whatsoever has been added. This is actually how it looks after the fleece has been sanded down. it needs to be sanded down flat so the fiberglass mat can go on flat and add strength. The putty you are talking about is actually body filly, in which case I use 2 different types.
One being Duraglass which is short strand body filler aka Reinforced Body Filler, which is used to build low spots and strength the pieces even further.
The second filler I use is Rage Xtreme which is a Lite Weight Body Filler which is spread and sanded down to be smooth for paint.
Hope this helps!
