Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 02-21-2008, 12:37 PM   #31
Creative0Mind is an unknown quantity at this point
Very nice work!!
CarPC: Mini-MAC Coming Soon!
/////AlpineTalk
For the Alpine Enthusiasts in you!
FS:: Lexus ES350: Complete Rear Seats
Creative0Mind is offline   Reply With Quote
Old 02-21-2008, 07:32 PM   #32
krnpimpsta's Avatar
krnpimpsta is an unknown quantity at this point
Ah, fleece! That's a great idea..
Do you have any experience with the Dynotron plastic bumper repair kit? Is Duraglass better or easier to use?
Also, do you have any recommendations on how to make straight lines in cramped areas? (see below: lines around my LCD are not straight and the rectangular hole for the DVD-ROM drive looks like a 5 year old cut it out of cheese...) I say cramped because I use a random orbit sander to get the front surface down flat, but it is too large and imprecise to do the inner edges - I tried..
I also wanted to bevel the area around the LCD - right now it's a 90 degree angle at the edge, but I'd like a larger rectangle to slope into the edge. Do you have any tips on what might make that easy & precise?
2008 Mustang GT CarPC
krnpimpsta is offline   Reply With Quote
Old 02-21-2008, 09:22 PM   #33
VENDOR - Nexations Creations
Nexson's Avatar
Nexson is on a distinguished road
Your work looks pretty good. What I use for all my bonding of pieces is Actually called CA Glue, basically it is like Super Glue on steriods, it actually smokes and crackles when the activator is sprayed on it to harden it. Duraglass is easy to use but only avaiable online or at a body shop supply stores. It will mainly help you get a smooth surface, but your area looks pretty small so I would just use the body filler.
As for getting straight edges, it is quite simple. Go and get your self some popsicle sticks. They are small and flat and will give you a nice straight edge to work with. What you want to do is cut back the edges of the screen to the size of the popsicle stick. From here, create a perfect square for your LCD using the sticks. Bond those sticks into the bezel, sand it down and then fill it. I would strongly suggest picking up a dremel at wal-mart for like $35. it is a great tool and I have been through about 10 of them myself (they burn out) but nonetheless it is a great tool when it is working. the dremel will allow you to tweak small areas, whereas your orbital sander is rather large and can only work with big surfaces.
As for the areas where you mentioned where you had a 90 angle. I would suggest just taking some 80 grit sand paper and wrap it around a small piece of wood to handle in your fingers, from here just hold the "sanding block" at the 90 angle until you have reach the slope you like!
hope this helps!
Nexson is offline   Reply With Quote
Old 02-21-2008, 10:00 PM   #34
krnpimpsta's Avatar
That's a great idea - popsicle sticks. I'll do that. I do have a dremel actually and it was what I used to make my crude rectangular opening for the DVD-ROM drive. The Dynotron had a consistency of thick tar and was basically impossible to shape, so I had to rely on dremelling/sanding after it set, to do the shaping. Hopefully I can start out with a much cleaner shape with popsicle sticks & the light filler you mentioned in an earlier post.
Since I'll be doing my second version on a new dash piece, I'll be starting from scratch. So I'm going to try using the stick idea for the bevelled areas too (I filled with alot of dynotron to get the 90 degree angle, after realizing that I couldn't make a decent beveled edge).
Thanks for all your help!
Old 02-22-2008, 12:45 AM   #35
Nexson's Avatar
Yea no problem, please keep me updated so I can help you out with your progress.
Old 02-26-2008, 03:03 PM   #36
hornyleprechaun is on a distinguished road
Love your work
hornyleprechaun is offline   Reply With Quote
Old 02-27-2008, 02:37 PM   #37
Nexson's Avatar
thanks yall!
Old 02-27-2008, 07:48 PM   #38
BasslineMilitia's Avatar
BasslineMilitia is an unknown quantity at this point
man thats fricken awesome work!!!
if only i was able to do that... all my interior is in maple.... and no one sells stuff for my car -__-
thats what it looks like except for that long strip of maple runnign along the right half of the dash. and i have no mini bar type thingy hehehe but the center is EXACTLY the same... and boy is it scary to work with. If i put a scratch on it i cant get another -__-....
so i got woofnstuff to get me a motorised single din touch screen. man... that was a ***** to install because the bracket inside wasn't even standard. when you go to eject the screen teh dash trim gets in the way so had to leave out too screws hahaha
can you make soemthing like this bro?
once again nice work bro!! Keep up the good work
BasslineMilitia is offline   Reply With Quote
Old 02-28-2008, 01:24 AM   #39
Kosti is on a distinguished road
This is great work champ!
How long would something like this take to construct?
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
Kosti is offline   Reply With Quote
Old 02-28-2008, 08:31 AM   #40
CherokeeChief's Avatar
CherokeeChief is on a distinguished road
This is my work, for my 1999 V8 Jeep Grand Cherokee:
It's a Jeep thing...you wouldn't understand !--------------------------------------------
CherokeeChief is offline   Reply With Quote
Old 02-28-2008, 08:44 PM   #41
john05srt4's Avatar
john05srt4 is an unknown quantity at this point
hey thats mine.. If Anyone is looking for some custom work dont fear mailing them to brian <nexson> He is a very stand up guy and trustworthy. I stand behind him 10000%
I am about to send you some stuff for my new XB.
My Accord CarPC
john05srt4 is offline   Reply With Quote
Old 02-28-2008, 09:01 PM   #42
Nexson's Avatar
Thanks John for the backup!
Can't wait to make the XB bezel happens for u!
Old 02-28-2008, 10:59 PM   #43
tacobandit is an unknown quantity at this point
Wow thats awesome, where are you located?
tacobandit is offline   Reply With Quote
Old 02-29-2008, 01:50 PM   #44
john05srt4's Avatar
hey brian I sent You an email.
I have my screen and bezel ready to ship to ya... call me sucka..
My Accord CarPC
Old 02-29-2008, 05:11 PM   #45
Hey Nexson, don't suppose you'll do any and send it to Syd Australia?
I'll send you more details, but I will try something here more locally, but your work looks great and I can see u take real pride in your work m8!
