The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Display Modes
Old 04-20-2008, 02:04 PM   #1
My Photos: (0)
how to simulate factory gray vinyl on dash?
i'm hoping to hack up an accessory console on my dash for a motorized LCD but would first like to know how the texture and color on a dashboard can be duplicated? my car is about 7 years old and the chance of an exact match seems hard.. would this mean i have to refinish the entire dash? thanks in advance!
liquid30 is offline   Reply With Quote
Sponsored Links
Old 04-20-2008, 04:13 PM   #2
rdholtz's CarPC Specs
rdholtz's Avatar
Location: edge of the tropics: Palm Beach Gardens, FL, USA
Vehicle: 2006 Scion xB
My Photos: (203)
First, give the dash a good cleaning to get the real color to show. Use a vinyl nourishing cream to get it bright.
Then find a material that's the same texture -- try Joanne Fabrics or the like, and get small samples of several colors, especially those close to what you want.
Finally, find a the color -- either a spray or in a tube -- you want to use on it. Keep working the color on the vinyl samples until you find one that's a match. Then cover your console.
If you can't make a match, you could still finish both pieces -- the dash and the console -- to match.
A final option would be to make the console a different but compatible color -- darker gray or lighter gray -- or a contrasting one like black.
It sounds so simple written out like that, but it takes some work. We did it several times on cars, but I haven't played with vinyl for a number of years, now. We used contact cement to adhere the vinyl, with good results.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 04-22-2008, 01:25 PM   #3
My Photos: (0)
thank i will try that, worse case scenario i will redo the entire dash and make a few mods along the way
Old 04-22-2008, 04:09 PM   #4
Wants to make it harder
monkeyracer's CarPC Specs
monkeyracer's Avatar
Vehicle: 2007 PT Cruiser Touring
My Photos: (63)
A lot of shops that sell automotive fabrics will have a HUGE selection of different shades and grains, etc, you might find the exact one for your car. Also, some (most) craft fabrics are not designed for colorfastness or higher heat in direct sunlight, so something designed for in-car use might yield better long term results. (And save some labor time on the back end...) In my area, a place called Keyston Bros is where I go to for this stuff. They have a way better selection than any of the craft stores.
2007 Chrysler PT Cruiser TE
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
monkeyracer is offline   Reply With Quote
Old 04-23-2008, 10:13 PM   #5
My Photos: (0)
you could find some vinyl that is close to your dash in color and texture.. (more so in texture). Wrap your piece then take a piece of your dash of the color you're looking for, i.e. your glove box door , etc. Take it to your local paint supply store.(automotive paint that is) and have them die match the color for you. That way even if you have faded coloring, they can match it perfect. They usually have some type of glass bottle with and aerosol top , like a spray can , that you can put it into and spray on the vinyl like paint.That way it's a perfect match to your dash.. Take your time stretching vinyl it can be difficult to work with. You should get something that will stretch in multiple directions making it easier to work with. A little bit of heat will help a great deal to.. Just warm it up get it too hot will melt the vinyl or show stryations or fingers in the vinyl.
dopey273 is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
3rd Time's the Charm??? Mercury Cougar Dash Lilliput antimatter Fabrication 23 08-07-2006 12:21 PM
Altima and In dash Video Canedriver Car Audio 3 09-11-2005 12:12 PM
padded dash material michaelrj9 Fabrication 2 06-13-2005 03:35 PM
trying to mould dash.... pls advise... CA 3000GT Fabrication 1 06-07-2005 05:51 PM
Anyone know where they sell vinyl dash kit sheets?? mykolJay Fabrication 5 08-04-2004 12:27 PM
Sponsored Links
Ad Management by RedTyger
