The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Display Modes
Old 06-29-2008, 02:09 PM   #1
My Photos: (8)
raw video monitors
question what and how is the best way to mount a raw monitor in a dash it has no trim to glass on? would you just build a wood frame around it but if thats the case how would you mount the monitor to the frame.
thanks derrick
cakenbake is offline   Reply With Quote
Sponsored Links
Old 06-29-2008, 07:32 PM   #2
hailrazer's CarPC Specs
hailrazer's Avatar
Vehicle: 2007 Gmc Yukon Xl
My Photos: (0)
You can easily mount the Lcd to a wooden frame with mirror clips.
Find them at any hardware store.
Of course this was with a raw panel with the backlight removed, but it works the same with a backlight. Just buy the size you need. Probably 1/4" or 3/8" mirror clips.
http://www.lowes.com/lowes/lkn?actio...444&lpage=none
My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
hailrazer is offline   Reply With Quote
Old 06-29-2008, 08:42 PM   #3
My Photos: (8)
thanks man i never would have thought of that
Old 06-29-2008, 11:32 PM   #4
rdholtz's CarPC Specs
rdholtz's Avatar
Location: edge of the tropics: Palm Beach Gardens, FL, USA
Vehicle: 2006 Scion xB
My Photos: (197)
Another option is to use a router to cut a groove in the frame for the screen to sit in. The advantage to the routed groove is that the frame provides the support, instead of supporting everything on the mirror clips.
The big advantages to the mirror clips: they're easier, faster, and cleaner. Use plenty to hold up that panel; the clips are inexpensive, compared to the LCD panel.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB -- CarPC installation worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 06-30-2008, 09:47 PM   #5
My Photos: (0)
damn great idea!!!!! surprised i didnt think of that! i went the router with a rabbet bit.
majinmajestyk is offline   Reply With Quote
Old 07-30-2008, 01:46 PM   #6
fatejd's CarPC Specs
Vehicle: 2006 Mazda 3 5-door
My Photos: (0)
How are you connecting the mirror clips? The screws on Lowes' website look a bit long to work and I've had bad luck trying to use screws in MDF.
Carputer Progress:
Re-do fabrication of screen [DONE]
Wood faceplate for computer in glovebox [0%]
fatejd is offline   Reply With Quote
Old 07-30-2008, 02:34 PM   #7
rdholtz's Avatar
My Photos: (197)
Two tricks to using screws in MDF:
  1. use sheet metal screws, which have no taper like wood screws do.
  2. drill the holes for them to be slightly larger than the shank of the screws, so only the threads are doing any work. You don't want to displace the MDF with the shank of the fastener. Drill almost as deep as the screw will go, so only the very tip is getting into undrilled MDF.
If there's much load on the fasteners, use screws as long as possible; for instance, if you're using 3/4 MDF, use 3/4 screws, because whatever you're fastening will take up some of the length.
If the load on the fasteners is light, you can use shorter screws, just long enough for a firm hold.
Sponsored Links
vB code is On
Trackbacks are Off
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 93 08-11-2008 09:40 PM
Video Driver Problem. Display blank starting at Welcome Screen 2k1Toaster General Hardware Discussion 20 01-07-2008 07:21 PM
onboard video vs a video card, power and cpu usage stapan General Hardware Discussion 2 06-09-2005 02:43 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
